Processors
14527 Discussions
What is the 4790K Stock Cache Multiplier (when Turbo Boosting)?
JSimo10
For the 4790K is the Cache/Uncore Ratio (Multiplier) suppose to follow the Core Multiplier when Turbo Boost is active?
I'm asking because it on the 4790K it seems to max out at x40 instead of x44 while my 4770K's cache followed the core ratio during Turbo Boost states (so x39).
Side note: This is on a Z87 chipset w/TDP & Current throttling disabled.
JSimo10
So I was bored and tried 44x as the cache multiplier. 4.4GHz cache crashes instantly when a heavy load is applied with stock voltage (Prime95 in this case).
Therefore I'm going to assume 40x is the correct Cache Ratio, at least for my CPU. -- Intel may set the cache ratio to follow Turbo (if stable) during binning, which is why my 4770K's cache multiplier followed Turbo boost.
Allan_J_Intel1
Thanks for joining the Processor community.
I am currently researching on this issue. As soon as I can, I will send you a message with my findings. Thank you for your patience and understanding.
Allan.
JSimo10
Thank-you Allan.
ASUS (my board manufacturer) doesn't exactly following Intel's specs, which is why I asked. -- For example if XMP memory is used the board completely ignores Intel's TDP/Current limits unless you key them in manually.
Allan_J_Intel1
I am still waiting for information from engineering. I will update this forum thread as soon as I get their feedback.
Allan.
JSimo10
Allan_J_Intel1
I'm glad it has been addressed. Thanks for sharing your experience.
Allan.
