Processors
14534 Discussions
What is the all core non-avx turbo freq of xeon gold 6256 and 6250?
Jiangv
Hi
what is the all core non-avx turbo freq of xeon gold 6256 and 6250?
the spec says max turbo freq is 4.5G, but what is the all core freq????
Emeth_O_Intel
Thank you for contacting Intel Xeon Community Support.
The Max Turbo Frequency of both Intel Xeon Processors is the same 4.50GHz".
The relevant difference is going to be applied in the voltage of the processor, for instance:
Non-AVX: 4.3ghz @ 1.10v.
AVX: 4.3ghz @ 1.14v.
So, it is going to affect the volage, as you can see the instructions AVX will require more voltage.
Moreover, could you please so kind and provide to me with more details about the configuration you are trying to achieve?
Emeth O.
Intel® Server Specialist.
Jiangv
Hi Emeth, sorry for the later reply.
I think you are misunderstanding me on this question.
Like the xeon gold 6244, it has a base freq 3.6G, max turbo non-avx freq of 4.4G, but once on all cores, it is only up to 4.3G
it turns out that 6244 can only maintain two cores running at 4.4G.
So I am asking here, for the new 6256/6250 processors, What is freqof non-AVX instructions on all cores, cause I do believe 4.5G is one or two cores only.
Thanks!
Emeth_O_Intel
I would like to know if the information provided helps you to clarify the information you are looking for.
If you have more questions do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Emeth_O_Intel
I am reviewing you thread and I have not seen any activity recently.
I am going to proceed and close this thread. If you have more questions do not hesitate and let us know and we will be more than happy to assit you.
Emeth O.
Emeth_O_Intel
Thank you for replying back.
In order to provide you the most accurate information about it, I will verify those details and as soon as possible I will be getting back to you in order to proceed with the next step.
Emeth O.
Jiangv
Emeth_O_Intel
Thank you so much for been waiting for my outcome.
Yes, I have good news for you. I was able to found the information you are looking for. However, this information is Intel Confidential. Do you already have a CNDA (Non-Disclosure Agreement.) with us?
Please let me know in order to proceed with the next step.
Emeth O.
Jiangv
Hi Emeth
Thanks for the reply, I just an end user so I have now CNDA with you.
But I dont know why such info need NDA? I mean for the previous chips you already write it in pdf freely for check, why this two chips are so secret?
Thanks!
Emeth_O_Intel
I understood your point, however, in this case as per the engineering department those details should be provided only under NDA.
Please let me know if you would like to proceed with the next step in order to send you a private message with those details.
Emeth O.
Jiangv
Emeth_O_Intel
I sent you the private message in order to proceed with the next step.
Please, let me know if you have some questions about this process and I will be more than happy to assist you.
Emeth O.
