In design guide indicated 68 ohm, in reference boards 85 ohm. What is correct?
Hi Rustres,
Please let me investigate about it, I'll let you know the outcome.
Hellen.
Hi Rustres,
The processor http://ark.intel.com/products/84311/Intel-Atom-Processor-E3805-1M-Cache-1_33-GHz Intel® Atom™ Processor E3805 (1M Cache, 1.33 GHz) is an embedded CPU and due to that and the nature of your question I would recommend that you contact an Intel Field Application Engineer in your region.
Additional resources for embedded processors are available here:http://www.intel.com/content/www/us/en/embedded/embedded-design-center.html Resources for Embedded and IoT Designers
Ronny G
Thanks Ronny, Rustres please let me know if it helps you, and if there is anything else I could do for you.
Hellen.
