In particular, I'm talking about Q370 vs C246.
When building a system based on Intel Core processor, is there an advantage or disadvantage in using a server chipset?
Hello AGutm2,
The differences between both chipsets are in the following link:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=133282,147326
In regards to the advantage or disadvantage, it depends on the purpose of your custom build.
Adrian M.
A Contingent Worker at Intel
Here is a spec comparison: https://www.intel.com/content/www/us/en/products/compare-products.html/chipsets?productIds=147324,133293. As you can see, there are very few differences. What could be a factor is the capabilities of the motherboard itself. Server motherboards may sacrifice performance for stability.
Hello AGutm2,
Were you able to check our previous posts?
Let us know if you need more assistance.
Adrian M.
Hello AGutm2,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
