Processors
14539 Discussions
What is the theoretical peak performance in Gflops of the Core i7 6850K at 3.60GHz
MCarc
I am trying to find out what is the theoretical peak performance in Gflops of the Core i7 6850K at 3.60GHz (the theoretical one, not the actual one on such or such application).
I have been all over the web and, strangely, could not find the answer.
Many thanks in advance
Manuel
Hello ____Manuel____,
Please let me review you inquiry, I will update the thread as soon as possible.
Amy.
MCarc
Hello Amy,
Thank you very much for handling my question.
Have you progressed on it?
I have found on the web a reference to the performance of the 6850K:
http://www.overclock.net/t/586994/cpu-gflop-performance-database CPU Gflop Performance Database
and it assigns to it a performance of 209.3 Gflops. However, as I understood, it is a measured performance only and not the theoretical peak performance. And I do need the theoretical peak performance (in double precision of course).
Manuel
/thread/112979 ____Manuel____, thank you for your patience.
Please see the document attached, this should address your Gflops inquiry.
If you have any questions, please let me know.
Amy.
/thread/112979 ____Manuel____, hope you were able to check my last input.
Amy.
