Processors
14536 Discussions
Whea-Logger
FLi12
Every time I run an android emulator like Bluestack I get this error in the event viewer
Event 19 Whea-Logger :
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Corrected Machine Check
Error Type: Internal parity error
Processor APIC ID: 2
The details view of this entry contains further information.
FLi12
My processor is i7 4720hq.
Hello Feview,
Thank you for joining the Processors Community.
I would like to gather more information regarding this matter, please see below for the information required.
  • What is the model of your computer?
  • What is the operating system installed?
  • Does your computer freeze/crash when running the emulator?
Thank you.
Amy C.
FLi12
Model:Asus Rog GL551JW
Window 10 64bit
My computer doesn't freeze or crash when running the emulator. The game is also smooth. However everytime I run the emulator the error pops up in event viewer.
I searched it up and it might cause BSOD.
Thank you for that information.
According to some third-party links from Microsoft forums, this event indicates that there is a hardware problem. A machine check exception indicates a computer hardware error that occurs when a computer's central processing unit detects a hardware problem. And, some of the suggestions to address this matter can be found below:
  • Update the BIOS and the drivers for the motherboard chipset.
  • Update all the hardware drivers, if updates are available from your manufacturer.
  • If you have overclocked your CPU, reset your settings to the default settings.
You should be able to find these drivers here: https://www.asus.com/ROG-Republic-Of-Gamers/ROG-G551JW/HelpDesk_Download/ ROG G551JW Driver & Tools| ROG - Republic Of Gamers | ASUS Global
Find the Microsoft link here: https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/whea-logger/897a3ec3-c92f-4b4e-980e-824ade948cf8 WHEA-LOGGER - Microsoft Community.
Amy C.
FLi12
I found out that these drivers needed to be updated.
Can you tell me where in intel can I find these drivers?
Intel(R) 8 Series/C220 Series PCI Express Root Port# 1 -8C10
Intel(R) Xeon(R0 processor E3-1200 v3/4th Gen Core processor
n_scott_pearson
There are no drivers for the processor, per se. What you need is the Intel Chipset Software package.
Now, as for where you get it, your primary source should be Asus. Asus is responsible for validating the drivers and software packages released by Intel on their products and Asus is responsible for making them available for download by their customers. One instance of the download page for your product is here: https://www.asus.com/us/Laptops/ROG-GL551JW/HelpDesk_Download/ ROG GL551JW Driver & Tools| Laptops | ASUS USA. Now, I see that Asus has a package posted there, but this is an out-of-date package. Typical. This likely means that Asus hasn't even validated the updated version. Ah well. Here is a link to download this package from the Intel site: https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility-?product=1145 Download Intel® Chipset Device Software (INF Update Utility).
Hope this helps,
