I saw something that linked to this warning: https://www.intel.com/content/www/us/en/developer/topic-technology/software-security-guidance/processors-affected-consolidated-product-cpu-model.html#tab-blade-1-1
It says to go to this GitHub to get the ucode file that will mitigate the risk. https://github.com/intel/Intel-Linux-Processor-Microcode-Data-Files/tree/main/intel-ucode
I can't tell which ucode file is the correct file to use. I'm using Linux. Here is information about my processor based on lscpu:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 39 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Vendor ID: GenuineIntel
Model name: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
CPU family: 6
Model: 142
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
Stepping: 10
CPU max MHz: 4000.0000
CPU min MHz: 400.0000
BogoMIPS: 3999.93
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfl
ush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm con
stant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpui
d aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma
cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes
xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_sin
gle pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fs
gsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflu
shopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hw
p_notify hwp_act_window hwp_epp flush_l1d
Is there a ucode file in that GitHub linked above that matches what I need? My computer is at least 5 years old, so maybe it's not listed there?
"Microcode can only be loaded via BIOS update."
Most Linux distributions usually attempt to update the CPU microcode during boot, using microcode_ctl. Most Linux distributions supply an up-to-date microcode file (CPU microcode can also be updated from within Windows: VMware had a tool to do this called the 'VMware CPU Microcode Update Driver' aka cpumcupdate, but it is no longer available from them: https://web.archive.org/web/20230321132457/https://flings.vmware.com/vmware-cpu-microcode-update-driver ).
For JP18's processor (with family+model+stepping of 6-8e-a), no new microcode has been issued by Intel since the 20230808 release according to https://github.com/intel/Intel-Linux-Processor-Microcode-Data-Files/tree/main/intel-ucode . If they are running a Linux distribution with updates more recent than that, they are probably already using the most up-to-date microcode for that CPU.
Hello JP18,
Before we proceed, let me gather more details.
1. When you say U-code, are you asking for Microcode for the processor?
2. What is the brand and model of your motherboard?
Michael L.
Hi, Michael.
I am trying to find the solution to this warning regarding Spectre V2 threats on linux. https://kb.cert.org/vuls/id/155143
That post includes this language:
"Solution
Please update your software according to the recommendations from respective vendors with the latest mitigations available to address this vulnerability and its variants."
So, I'm trying to find code that applies a patch to my processor that can mitigate the threat from Spectre V2. I don't know if that's "U-code" or Microcode or what. There was a link to this page for solutions:
Specifically, Footnote 2. The GitHub page says "u-code", so that's why I called it u-code. Whatever it's called.
Here is the motherboard info:
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.1.0 present.
Handle 0x0002, DMI type 2, 17 bytes
Base Board Information
Manufacturer: HP
Product Name: 8416
Version: KBC Version 05.37.00
Serial Number: PGWJP00WBC90EF
Asset Tag:
Features:
Board is a hosting board
Location In Chassis:
Chassis Handle: 0x0000
Type: Motherboard
Contained Object Handles: 0
Sincerely,
JP
It occurs to me that I wrote "u-code" because that's what was on the GitHub page. The GitHub page used the English "u" as the closest thing to the Greek symbol for "micro". Something to do with UTF-8 vs ASCII or whatever and which of those is allowed in the title of a GitHub page. So, yes, I'm looking for microcode.
Hello JP18,
Thank you for the clarification.
Microcode can only be loaded via BIOS update. Usually, Please check this link for more details:
Michael L.
That link looks helpful, but it doesn't answer my question: which microcode file do I need from the GitHub repo I referred to in OP?
I used dmesg and I get this:
smpboot: CPU0: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz (family: 0x6, model: 0x8e, ste
pping: 0xa)
So, I think the family+model+stepping is: 6-8e-a
Which leads me to think I need the microcode from here:
https://github.com/intel/Intel-Linux-Processor-Microcode-Data-Files/blob/main/intel-ucode/06-8e-0a
Is this correct?
Thanks for the reply, cowbat. I found a script for checking for CPU vulnerabilities. This is the GitHub repo for the script:
https://github.com/speed47/spectre-meltdown-checker/blob/master/FAQ.md
I ran the script. The result is lengthy.
The TL;DR is that there seem to be some vulnerabilities that could be addressed by an update to microcode.
While I'd like to apply a patch due the apparent vulnerabilities, some of the reading I did about doing so advised against messing with microcode on one's own. I'm no guru and I've never tried to patch microcode before, thus I'm hesitant. I will try to see if there has been some kind of patch provided by my distro in the last couple of years.
This is the script's output:
Spectre and Meltdown mitigation detection tool v0.46+
Checking for vulnerabilities on current system
Kernel is [35mLinux 5.15.145 #1 SMP PREEMPT Sun Dec 24 00:07:06 CST 2023 x86_64[0m
CPU is [35mIntel(R) Core(TM) i7-8550U CPU @ 1.80GHz[0m
[1;34mHardware check[0m
* Hardware support (CPU microcode) for mitigation techniques
* Indirect Branch Restricted Speculation (IBRS)
* SPEC_CTRL MSR is available: [42m[30m YES [0m
* CPU indicates IBRS capability: [42m[30m YES [0m (SPEC_CTRL feature bit)
* Indirect Branch Prediction Barrier (IBPB)
* CPU indicates IBPB capability: [42m[30m YES [0m (SPEC_CTRL feature bit)
* Single Thread Indirect Branch Predictors (STIBP)
* CPU indicates STIBP capability: [42m[30m YES [0m (Intel STIBP feature bit)
* Speculative Store Bypass Disable (SSBD)
* CPU indicates SSBD capability: [42m[30m YES [0m (Intel SSBD)
* L1 data cache invalidation
* CPU indicates L1D flush capability: [42m[30m YES [0m (L1D flush feature bit)
* Microarchitectural Data Sampling
* VERW instruction is available: [43m[30m NO [0m
* Indirect Branch Predictor Controls
* Indirect Predictor Disable feature is available: [43m[30m NO [0m
* Bottomless RSB Disable feature is available: [43m[30m NO [0m
* BHB-Focused Indirect Predictor Disable feature is available: [43m[30m NO [0m
* Enhanced IBRS (IBRS_ALL)
* CPU indicates ARCH_CAPABILITIES MSR availability: [43m[30m NO [0m
* ARCH_CAPABILITIES MSR advertises IBRS_ALL capability: [43m[30m NO [0m
* CPU explicitly indicates not being affected by Meltdown/L1TF (RDCL_NO): [43m[30m NO [0m
* CPU explicitly indicates not being affected by Variant 4 (SSB_NO): [43m[30m NO [0m
* CPU/Hypervisor indicates L1D flushing is not necessary on this system: [43m[30m NO [0m
* Hypervisor indicates host CPU might be affected by RSB underflow (RSBA): [44m[30m NO [0m
* CPU explicitly indicates not being affected by Microarchitectural Data Sampling (MDS_NO): [43m[30m NO [0m
* CPU explicitly indicates not being affected by TSX Asynchronous Abort (TAA_NO): [43m[30m NO [0m
* CPU explicitly indicates not being affected by iTLB Multihit (PSCHANGE_MSC_NO): [43m[30m NO [0m
* CPU explicitly indicates having MSR for TSX control (TSX_CTRL_MSR): [43m[30m NO [0m
* CPU explicitly indicates being affected by GDS and having mitigation control (GDS_CTRL): [44m[30m NO [0m
* CPU explicitly indicates not being affected by GDS (GDS_NO): [43m[30m NO [0m
* CPU supports Transactional Synchronization Extensions (TSX): [43m[30m NO [0m
* CPU supports Software Guard Extensions (SGX): [44m[30m YES [0m
* CPU supports Special Register Buffer Data Sampling (SRBDS): [42m[30m NO [0m
* CPU microcode is known to cause stability problems: [44m[30m NO [0m (family 0x6 model 0x8e stepping 0xa ucode 0x9a cpuid 0x806ea pfid 0x1)
* CPU microcode is the latest known available version: [44m[30m UNKNOWN [0m (latest microcode version for your CPU model is unknown)
* CPU vulnerability to the speculative execution attack variants
* Affected by CVE-2017-5753 (Spectre Variant 1, bounds check bypass): [43m[30m YES [0m
* Affected by CVE-2017-5715 (Spectre Variant 2, branch target injection): [43m[30m YES [0m
* Affected by CVE-2017-5754 (Variant 3, Meltdown, rogue data cache load): [43m[30m YES [0m
* Affected by CVE-2018-3640 (Variant 3a, rogue system register read): [43m[30m YES [0m
* Affected by CVE-2018-3639 (Variant 4, speculative store bypass): [43m[30m YES [0m
* Affected by CVE-2018-3615 (Foreshadow (SGX), L1 terminal fault): [43m[30m YES [0m
* Affected by CVE-2018-3620 (Foreshadow-NG (OS), L1 terminal fault): [43m[30m YES [0m
* Affected by CVE-2018-3646 (Foreshadow-NG (VMM), L1 terminal fault): [43m[30m YES [0m
* Affected by CVE-2018-12126 (Fallout, microarchitectural store buffer data sampling (MSBDS)): [43m[30m YES [0m
* Affected by CVE-2018-12130 (ZombieLoad, microarchitectural fill buffer data sampling (MFBDS)): [43m[30m YES [0m
* Affected by CVE-2018-12127 (RIDL, microarchitectural load port data sampling (MLPDS)): [43m[30m YES [0m
* Affected by CVE-2019-11091 (RIDL, microarchitectural data sampling uncacheable memory (MDSUM)): [43m[30m YES [0m
* Affected by CVE-2019-11135 (ZombieLoad V2, TSX Asynchronous Abort (TAA)): [43m[30m YES [0m
* Affected by CVE-2018-12207 (No eXcuses, iTLB Multihit, machine check exception on page size changes (MCEPSC)): [43m[30m YES [0m
* Affected by CVE-2020-0543 (Special Register Buffer Data Sampling (SRBDS)): [43m[30m YES [0m
* Affected by CVE-2023-20593 (Zenbleed, cross-process information leak): [42m[30m NO [0m
* Affected by CVE-2022-40982 (Downfall, gather data sampling (GDS)): [43m[30m YES [0m
* Affected by CVE-2023-20569 (Inception, return address security (RAS)): [42m[30m NO [0m
* Affected by CVE-2023-23583 (Reptar, redundant prefix issue): [42m[30m NO [0m
[1;34mCVE-2017-5753 aka 'Spectre Variant 1, bounds check bypass'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (Mitigation: usercopy/swapgs barriers and __user pointer sanitization)
* Kernel has array_index_mask_nospec: [42m[30m YES [0m (1 occurrence(s) found of x86 64 bits array_index_mask_nospec())
* Kernel has the Red Hat/Ubuntu patch: [43m[30m NO [0m
* Kernel has mask_nospec64 (arm64): [43m[30m NO [0m
* Kernel has array_index_nospec (arm64): [43m[30m NO [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (Mitigation: usercopy/swapgs barriers and __user pointer sanitization)
[1;34mCVE-2017-5715 aka 'Spectre Variant 2, branch target injection'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (Mitigation: IBRS, IBPB: conditional, STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected)
* Mitigation 1
* Kernel is compiled with IBRS support: [42m[30m YES [0m
* IBRS enabled and active: [42m[30m YES [0m
* Kernel is compiled with IBPB support: [42m[30m YES [0m
* IBPB enabled and active: [42m[30m YES [0m
* Mitigation 2
* Kernel has branch predictor hardening (arm): [43m[30m NO [0m
* Kernel compiled with retpoline option: [42m[30m YES [0m
* Kernel supports RSB filling: [42m[30m YES [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (IBRS + IBPB are mitigating the vulnerability)
[1;34mCVE-2017-5754 aka 'Variant 3, Meltdown, rogue data cache load'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (Mitigation: PTI)
* Kernel supports Page Table Isolation (PTI): [42m[30m YES [0m
* PTI enabled and active: [42m[30m YES [0m
* Reduced performance impact of PTI: [42m[30m YES [0m (CPU supports INVPCID, performance impact of PTI will be greatly reduced)
* Running as a Xen PV DomU: [44m[30m NO [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (Mitigation: PTI)
[1;34mCVE-2018-3640 aka 'Variant 3a, rogue system register read'[0m
* CPU microcode mitigates the vulnerability: [42m[30m YES [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (your CPU microcode mitigates the vulnerability)
[1;34mCVE-2018-3639 aka 'Variant 4, speculative store bypass'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (Mitigation: Speculative Store Bypass disabled via prctl and seccomp)
* Kernel supports disabling speculative store bypass (SSB): [42m[30m YES [0m (found in /proc/self/status)
* SSB mitigation is enabled and active: [42m[30m YES [0m (per-thread through prctl)
* SSB mitigation currently active for selected processes: [42m[30m YES [0m (dhcpcd firefox-bin)
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (Mitigation: Speculative Store Bypass disabled via prctl and seccomp)
[1;34mCVE-2018-3615 aka 'Foreshadow (SGX), L1 terminal fault'[0m
[1;34mCVE-2018-3620 aka 'Foreshadow-NG (OS), L1 terminal fault'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (Mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable)
* Kernel supports PTE inversion: [42m[30m YES [0m (found in kernel image)
* PTE inversion enabled and active: [42m[30m YES [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (Mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable)
[1;34mCVE-2018-3646 aka 'Foreshadow-NG (VMM), L1 terminal fault'[0m
* Information from the /sys interface: Mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
* This system is a host running a hypervisor: [42m[30m NO [0m
* Mitigation 1 (KVM)
* EPT is disabled: [43m[30m NO [0m
* Mitigation 2
* L1D flush is supported by kernel: [42m[30m YES [0m (found flush_l1d in /proc/cpuinfo)
* L1D flush enabled: [42m[30m YES [0m (conditional flushes)
* Hardware-backed L1D flush supported: [42m[30m YES [0m (performance impact of the mitigation will be greatly reduced)
* Hyper-Threading (SMT) is enabled: [43m[30m YES [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (this system is not running a hypervisor)
[1;34mCVE-2018-12126 aka 'Fallout, microarchitectural store buffer data sampling (MSBDS)'[0m
* Mitigated according to the /sys interface: [43m[30m NO [0m (Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable)
* Kernel supports using MD_CLEAR mitigation: [42m[30m YES [0m (found md_clear implementation evidence in kernel image)
* Kernel mitigation is enabled and active: [43m[30m NO [0m
* SMT is either mitigated or disabled: [43m[30m NO [0m
> [46m[30mSTATUS:[0m [41m[30m VULNERABLE [0m (Your kernel supports mitigation, but your CPU microcode also needs to be updated to mitigate the vulnerability)
[1;34mCVE-2018-12130 aka 'ZombieLoad, microarchitectural fill buffer data sampling (MFBDS)'[0m
[1;34mCVE-2018-12127 aka 'RIDL, microarchitectural load port data sampling (MLPDS)'[0m
[1;34mCVE-2019-11091 aka 'RIDL, microarchitectural data sampling uncacheable memory (MDSUM)'[0m
[1;34mCVE-2019-11135 aka 'ZombieLoad V2, TSX Asynchronous Abort (TAA)'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (Not affected)
* TAA mitigation is supported by kernel: [42m[30m YES [0m (found tsx_async_abort in kernel image)
* TAA mitigation enabled and active: [43m[30m NO [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (Not affected)
[1;34mCVE-2018-12207 aka 'No eXcuses, iTLB Multihit, machine check exception on page size changes (MCEPSC)'[0m
* Mitigated according to the /sys interface: [42m[30m YES [0m (KVM: Mitigation: VMX disabled)
* iTLB Multihit mitigation is supported by kernel: [42m[30m YES [0m (found itlb_multihit in kernel image)
* iTLB Multihit mitigation enabled and active: [42m[30m YES [0m (KVM: Mitigation: VMX disabled)
[1;34mCVE-2020-0543 aka 'Special Register Buffer Data Sampling (SRBDS)'[0m
* Mitigated according to the /sys interface: [43m[30m NO [0m (Vulnerable: No microcode)
* SRBDS mitigation control is supported by the kernel: [42m[30m YES [0m (found SRBDS implementation evidence in kernel image. Your kernel is up to date for SRBDS mitigation)
* SRBDS mitigation control is enabled and active: [43m[30m NO [0m
> [46m[30mSTATUS:[0m [41m[30m VULNERABLE [0m (Your CPU microcode may need to be updated to mitigate the vulnerability)
[1;34mCVE-2023-20593 aka 'Zenbleed, cross-process information leak'[0m
* Zenbleed mitigation is supported by kernel: [42m[30m YES [0m (found zenbleed message in kernel image)
* Zenbleed kernel mitigation enabled and active: [44m[30m N/A [0m (CPU is incompatible)
* Zenbleed mitigation is supported by CPU microcode: [43m[30m NO [0m
> [46m[30mSTATUS:[0m [42m[30m NOT VULNERABLE [0m (your CPU vendor reported your CPU model as not affected)
[1;34mCVE-2022-40982 aka 'Downfall, gather data sampling (GDS)'[0m
* GDS is mitigated by microcode: [43m[30m NO [0m
* Kernel supports software mitigation by disabling AVX: [42m[30m YES [0m (found gather_data_sampling in kernel image)
* Kernel has disabled AVX as a mitigation: [43m[30m NO [0m (AVX support is enabled)
> [46m[30mSTATUS:[0m [41m[30m VULNERABLE [0m (Vulnerable: No microcode)
[1;34mCVE-2023-20569 aka 'Inception, return address security (RAS)'[0m
* Kernel supports mitigation: [42m[30m YES [0m (found spec_rstack_overflow in kernel image)
* Kernel compiled with SRSO support: [42m[30m YES [0m
* Kernel compiled with IBPB_ENTRY support: [42m[30m YES [0m
[1;34mCVE-2023-23583 aka 'Reptar, redundant prefix issue'[0m
> [46m[30mSUMMARY:[0m [42m[30mCVE-2017-5753:OK[0m [42m[30mCVE-2017-5715:OK[0m [42m[30mCVE-2017-5754:OK[0m [42m[30mCVE-2018-3640:OK[0m [42m[30mCVE-2018-3639:OK[0m [42m[30mCVE-2018-3615:OK[0m [42m[30mCVE-2018-3620:OK[0m [42m[30mCVE-2018-3646:OK[0m [41m[30mCVE-2018-12126:KO[0m [41m[30mCVE-2018-12130:KO[0m [41m[30mCVE-2018-12127:KO[0m [41m[30mCVE-2019-11091:KO[0m [42m[30mCVE-2019-11135:OK[0m [42m[30mCVE-2018-12207:OK[0m [41m[30mCVE-2020-0543:KO[0m [42m[30mCVE-2023-20593:OK[0m [41m[30mCVE-2022-40982:KO[0m [42m[30mCVE-2023-20569:OK[0m [42m[30mCVE-2023-23583:OK[0m
I thought I replied to this. I used a script that can find vulnerabilities in a CPU. https://github.com/speed47/spectre-meltdown-checker and it indicates that the CPU is vulnerable and that there are some microcode updates that can address some of the vulnerabilities. It seems like I'll have to see what updates my distro has provided and maybe contemplate how to proceed.
I appreciate cowbat confirming the version of microcode I need. That was all I was asking for to begin with.
What's the full output of the spectre-meltdown-checker script on the system with that CPU?
What Linux distro are you using?
According to the data source it uses, https://www.intel.com/content/www/us/en/developer/topic-technology/software-security-guidance/processors-affected-consolidated-product-cpu-model.html , CPUID Family_Model 06_8E with Stepping A is advised by Intel to have the 0xf4 microcode update (MCU) in order to mitigate the most recent vulnerability (https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00828.html) that requires a microcode update. INTEL-SA-00828 was released on 08/08/2023 which agrees with the most recent microcode for your CPU from https://github.com/intel/Intel-Linux-Processor-Microcode-Data-Files/tree/main/intel-ucode
I'd be amazed (and disappointed) if any current Linux distro isn't shipping CPU microcode updates that include that 20230808 release, some 9 months after Intel released it. Frankly, I'd expect even the most recent 20240312 release to be included by now, nearly 2 months later. If you're missing the most recent microcode update, perhaps you don't have the microcode_ctl package installed or configured to run on boot?
The output is quite lengthy.
The distro is Slackware. I have to look to see if the update was installed or not.
Hello JP18,
Thank you for the quick reply.
It is recommended to contact the manufacturer of the board for more details microcode since it is updated via BIOS update.
They should be able to explained if your system already have the needed update.
Michael L.
