Processors
14534 Discussions
Which processor is better Q9000 or I7-720QM?
Can anybody answer my question .. Which processor is better Q9000 or I7-720QM?
Which processor has a higher clock speed Q9000 or I7-720QM?
I'm confused with the overclocking thing.
John_S_Intel
Which processor is "better" kind of depends upon what you expect from your laptop. There is a web site you can use to review and compare the features & specs of these two processors side-by-side. Please see the features comparison at the following link: http://ark.intel.com/Compare.aspx?ids=40480,43122 http://ark.intel.com/Compare.aspx?ids=40480,43122.
In general, here are some ways you might differentiate the two processors you are trying to compare.
Differences:
While both of these processors you are asking about are quad core processors, the Intel Core i7-720QM processor features hyperthreading (4 cores, 8 threads) while the Intel® Core™2 Quad Processor Q9000 does not feature hyperthreading (4 cores, 4 thread).
The Q9000 is a 2GHz CPU (max frequency), whereas the 720QM is a 1.6GHz CPU that features Intel turbo boost technology and can run at up to 2.8GHz (max turbo frequency).
These two processors are not socket compatible (not interchangeable). The http://download.intel.com/design/processor/datashts/320390.pdf Intel® Core™2 Quad Mobile Processor (9000) supports the Mobile Intel® 4 Series Express Chipset Family. The next generation http://download.intel.com/design/processor/datashts/320765.pdf Intel® Core™ i7 Mobile Processor (i7-720QM) supports the newer Intel® 5 Series Chipset.
Similarities:
Both of these processors are intended for systems with discrete graphics, they each feature 6MB Cache, and each has a max TDP of 45W.
Processor NumberQ9000i7-720QM# of Cores44# of Threads48Clock Speed2 GHz1.6 GHzMax Turbo Frequencyn/a2.8 GHzCache6 MB L2 Cache6 MB Intel® Smart CacheSockets SupportedPGA478PGA988
John S.
Intel Customer Support
*Other names and brands may be claimed as the property of others.
zwartsjohn
hello john
are you sure the q9000 is for the mobile intel 4 series
greetings john
If you have teh choice and the price difference isn't that much i would for teh i7-729QM, newer technology, more threads and with turbo boost higher clock speed when needed, probably better power management too.
don't worry about teh overclocking as you don't really do that on a laptop anywyas, normally they won't have teh cooling for it.
AlHill
@zwartsjohn You do realize this is an 11-year old thread, correct?
[Windows 11 is the new Vista]
