I'm just curious but why is the IHS no longer soldered on chips like the 4770K, 6700K, 7700K etc....? It's been proven time and time again that a soldered IHS lowers temperatures by quite a huge margin and is far superior to using the toothpaste that the Intel assembly line use.
Surely it cannot be that much more expensive, If AMD can do it wit their Ryzen chips then Intel who have a lot more money can do it with their chips.
Hello Dicehunter,
I understand that you would like information as to why the IHS is not soldered.
I have sent you a private message.
David V
Hello Dicehunter,
I am following up with your case and see that we have not heard back from you.
Were you able to read the message I sent you?
If you need more assistance do not hesitate to reply.
David V
