Processors
14509 Discussions
Why can't I see my flash partitions in /proc/mtd
JMurr12
I have the following in my .dts file:
flash@0xff705000 {
            compatible = "cadence,qspi-14.0", "cadence,qspi";
            reg = <0xff705000 0x1000 0xffa00000 0x1000>;
            reg-names = "axi_slave0", "axi_slave1";
            interrupt-parent = <0x3>;
            interrupts = <0x0 0x97 0x4>;
            clocks = <0x22>;
            bus-num = <0x2>;
            fifo-depth = <0x80>;
            num-chipselect = <0x4>;
            status = "okay";
            bank-width = <0x2>;
            device-width = <0x1>;
            #address-cells = <0x1>;
            #size-cells = <0x0>;
            master-ref-clk = <0x17d78400>;
            ext-decoder = <0x0>;
            n25q00@0 {
                compatible = "n25q00";
                #size-cells = <0x1>;
                reg = <0x0>;
                spi-max-frequency = <0x5f5e100>;
                page-size = <0x100>;
                block-size = <0x10>;
                m25p,fast-read;
                read-delay = <0x4>;
                tshsl-ns = <0x32>;
                tsd2d-ns = <0x32>;
                tchsh-ns = <0x4>;
                tslch-ns = <0x4>;
                partition@0 {
                    label = "Flash 0 Raw Data";
                    reg = <0x0 0x800000>;
                partition@800000 {
                    label = "Flash 1 jffs2 Filesystem";
                    reg = <0x800000 0x1000000>;
                partition@1800000 {
                    label = "FPGA Image";
                    reg = <0x1800000 0x800000>;
JMurr12
Built with latest version of Linux.
Now the bootlog shows the cadence-qspi driver but says the chip has unrecognized JEDEC id bytes (not ffff).
Suspect I still have this configured incorrectly.
Does anyone have dts entry for this?
My dts is now:
        spi@0xff705000 {
            compatible = "cdns,qspi-nor";
            reg = <0xff705000 0x1000>, <0xffa00000 0x1000>;
            clocks = <0x22>;
            cdns,fifo-depth = <0x80>;
            cdns,fifo-width = <0x4>;
            cdns,trigger-address = <0x0>;
            resets = <0x26 0x25>;
            status = "okay";
            n25q00@0 {
                reg = <0x0>;
                m25p,fast-read;
                cdns,page-size = <0x100>;
                cdns,block-size = <0x10>;
                cdns,read-delay = <0x4>;
                cdns,tshsl-ns = <0x32>;
                cdns,tsd2d-ns = <0x32>;
                cdns,tchsh-ns = <0x4>;
                cdns,tslch-ns = <0x4>;
                partition@0 {
                partition@800000 {
                    reg = <0x800000 0x7800000>;
JMurr12
Got this working.
Changed read-delay to 3.
