I have the following in my .dts file:
flash@0xff705000 {
compatible = "cadence,qspi-14.0", "cadence,qspi";
reg = <0xff705000 0x1000 0xffa00000 0x1000>;
reg-names = "axi_slave0", "axi_slave1";
interrupt-parent = <0x3>;
interrupts = <0x0 0x97 0x4>;
clocks = <0x22>;
bus-num = <0x2>;
fifo-depth = <0x80>;
num-chipselect = <0x4>;
status = "okay";
bank-width = <0x2>;
device-width = <0x1>;
#address-cells = <0x1>;
#size-cells = <0x0>;
master-ref-clk = <0x17d78400>;
ext-decoder = <0x0>;
n25q00@0 {
compatible = "n25q00";
#size-cells = <0x1>;
reg = <0x0>;
spi-max-frequency = <0x5f5e100>;
page-size = <0x100>;
block-size = <0x10>;
m25p,fast-read;
read-delay = <0x4>;
tshsl-ns = <0x32>;
tsd2d-ns = <0x32>;
tchsh-ns = <0x4>;
tslch-ns = <0x4>;
partition@0 {
label = "Flash 0 Raw Data";
reg = <0x0 0x800000>;
partition@800000 {
label = "Flash 1 jffs2 Filesystem";
reg = <0x800000 0x1000000>;
partition@1800000 {
label = "FPGA Image";
reg = <0x1800000 0x800000>;
Built with latest version of Linux.
Now the bootlog shows the cadence-qspi driver but says the chip has unrecognized JEDEC id bytes (not ffff).
Suspect I still have this configured incorrectly.
Does anyone have dts entry for this?
My dts is now:
spi@0xff705000 {
compatible = "cdns,qspi-nor";
reg = <0xff705000 0x1000>, <0xffa00000 0x1000>;
clocks = <0x22>;
cdns,fifo-depth = <0x80>;
cdns,fifo-width = <0x4>;
cdns,trigger-address = <0x0>;
resets = <0x26 0x25>;
status = "okay";
n25q00@0 {
reg = <0x0>;
m25p,fast-read;
cdns,page-size = <0x100>;
cdns,block-size = <0x10>;
cdns,read-delay = <0x4>;
cdns,tshsl-ns = <0x32>;
cdns,tsd2d-ns = <0x32>;
cdns,tchsh-ns = <0x4>;
cdns,tslch-ns = <0x4>;
partition@0 {
partition@800000 {
reg = <0x800000 0x7800000>;
Got this working.
Changed read-delay to 3.
