Hello everyone,
Recently I got myself a new motherboard with a PCI-e 3.0 slot on it. Unfortunately I still have a second generation i7 (2600) which means I cannot use the capacity of the slot, since it requires a 3rd generation processor.
My question is: will the slot still work if I put a graphics card in it? For example, if I put an MSI Radeon R9 390x into it, is it just going to be a little slower? Or is it not going to work at all? In that case I guess I'll have to buy a new processor first.
- Tags:
- PCIe
Hello Smiekero,
In this case for the Intel® Core™ i7-2600 Processor specification is that it will support PCI Express Revision 2.0, here you can check the specs http://ark.intel.com/products/52213/Intel-Core-i7-2600-Processor-8M-Cache-up-to-3_80-GHz# @specifications ARK | Intel® Core™ i7-2600 Processor (8M Cache, up to 3.80 GHz); however you will be able to run it on your motherboard but it will run under the parameters of PCI Express 2.0 instead of the 3.0.
Amy.
Hello Smiekero,
Amy.
Hello Amy,
Thanks for the help!
Kind regards,
Smiekero
