Will the following Intel CPU support the AI of 24H2?
Intel(R) Core(TM i9-10900 CPU @ 2.80GHz, 2808GHz, 10 Core(s), 20 Logical Processor(s)
Hello DrewCI,
Regarding your inquiry, it is best to check the system requirements or the validated hardware for AI of 24H2.
Kindly check this link to access the Intel Product Compatibility tool and click on Processor OS Compatibility for the details.
Michael L.
Hello DrewCI,
Michael L.
Hello DrewCI,
I am sending another follow up to check if you were able read the link we provided.
Michael L.
Mike,
Excuse the delay in answering you. I had the answer from other sources before you initially replied. That answer is YES.
14th Gen with NPU is not needed nor necessary, though certainly even better. (BUT) My hunch that my 10th Gen is ok for AI is correct.
Thanks anyway.
Cheers,
Drew
