As title says, when I took the processor out for cleaning I notice a little scratch on the back..
I m worried it will void my warranty..The cpu works just fine not overheating or other errors, works as it needs to be.
https://imageshack.com/i/pnt5yLjNj ImageShack - Best place for all of your image hosting and image sharing needs (also I think there is a little bit of thermal paste too up there on those two pads and I got rid of them after taking the picture)
Vladonee: Thank you very much for joining the Intel® Processors communities.
In regard to your inquiry, every case is different and depending on the issue we will start an investigation in order to reach a resolution. Normally the way it works is that the warranty department, if the is unit under the 3 years of warranty, crates the RMA for you to send the processor to our depot, once the unit gets there it will be analyzed and a decision will be made if it can be replaced or not.
Any further questions, please let me know.
Alberto R
