Processors
13843 Discussions
Windows 10. Why does 12600k park so many cores? Cores are not fully hyperthreaded
pman62
using Windows 10.
under normal usage, the cpu is not hyperthreading properly
or is this expected behavior?
If i disable the e-cores on the 12600k, all p-cores are fully utilized. I have 12 hyperthread cores.
if I leave e-cores enabled, I virtually have only 10 cores.... 6-non-ht p-cores, and 4 ecores.
it looks as though hyperthreading is effectively disabled when the e-cores are used.
what's going on here?
When e-cores are disabled, hyperthreading returns to  normal...
David_G_Intel
Hello pman62
Thank you for posting on the Intel️® communities. To investigate this, please share with us the following:
  • Motherboard model and BIOS version
  • Windows version and build
  • Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
