Se apagó el sistema debido a un evento térmico crítico.
Hora de apagado = 2020-04-11T23:45:45.520818700Z
Zona térmica ACPI = Intel(R) Dynamic Platform Thermal Framework
_CRT = 373K
That update was provided by Dell. I installed it on my laptop (E7470) and all is fine.
Contact Dell for support with their update.
Doc
Thank you for your review and response. Sure enough, the driver has a January 2020 update, I downloaded it from the dell page, but the error remains
https://www.dell.com/support/home/co/es/cobsdt1/drivers/DriversDetails?driverId=9HWMD
Nombre del sistema operativo: Microsoft Windows 10 Pro
Versión del sistema operativo: 10.0.18363 N/D Compilación 18363
You need to contact Dell regarding this issue. Or, remove the driver. Or, rollback to a checkpoint prior to you installing the driver.
Doc
