Processors
13841 Discussions
With CONFIGURATION_NEEDED and the Intel-SA ID off the whitelist
zhnfl
How do I make the RA report return SW_HARDENING_NEEDED or have CONFIGURATION_NEEDED and the INT-SA ID all on the whitelist
MAG Z390M MORTAR(MS-7C00)and Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
system Ubuntu20.04
advisoryIDs = "INTEL-SA-00219", "INTEL-SA-00289", "INTEL-SA-00334"
David_G_Intel
Hello zhnfl
Thank you for posting on the Intel️® communities.
Please share more information with us:
  • What do you mean by the "RA report"? What is the specific information you require?
  • For the SAs, make sure your system is up to date (BIOS and drivers, includingIntel® Software Guard Extensions (Intel® SGX) Driver )
  • Is there a specific issue with one of the programs you use? Please explain more about the impact.
David G
Intel Customer Support Technician
David_G_Intel
Hello zhnfl
David G
zhnfl
Now all I have left is Intel-SA-00289 to be solved. However, I5-9600KF does not support overclocking, and BIOS does not support overclocking, so I am in trouble now
David_G_Intel
Thank you for the update @zhnfl. You can check all the information for this SA on the Intel® website:
The recommended action is to update the BIOS to the latest version provided by the motherboard manufacturer.
David G
David_G_Intel
Let us know if you need anything else.
David G.
David_G_Intel
David G.
