The graphics card driver for 1240P has a BUG. When starting DX12 in Plants vs. Zombies and the defense of harmony town, there is a screen flashing issue with all bright spots, which makes it impossible to play. Please provide feedback.
Hello 1240P,
- What is the model of your Graphics Controller?
- What is the model of your processor?
- What is the complete model of your system?
- Was it working fine before?
- Did you change any settings before the issue started?
- What are the troubleshooting steps that you tried so far?
Michael L.
My CPU is 1240p, the graphics card is Xe (80EU), the memory is 4266MHz, the system is Windows 10 Enterprise Edition 22H2, and the driver is 101.6460-101.6259. I haven't changed any options. I don't know if the Arc graphics card will also have this issue, but the Xe graphics card has indeed encountered this problem.
And I found that this bug only exists under DX12, while it's normal under DX11. But as is well known, Xe is notoriously poor under DX11.
And for some reason, the more the driver is updated, the more bugs, at least the previous version of the driver I remember did not have this bug, but then it appeared.
我的 CPU 是 1240p,显卡是 Xe (80EU),内存是 4266MHz,系统是 Windows 10 企业版 22H2,驱动是 101.6460-101.6259。我没有更改任何选项。不知道 Arc 显卡会不会也会出现这个问题,但 Xe 显卡确实遇到过这个问题。
Message Body
Hello 1240P,
Thank you for the update.
Let me gather more details to further investigate this issue.
- What is the brand and model of your laptop?
- Can you still remember the driver version when it was working fine?
- Please help generate the SSU logs of your system. Kindly refer to the link below on how to get the logs:
Michael L.
Hello 1240P,
Michael L.
Hello 1240P,
I am sending another follow up on the information that I requested.
Michael L.
