Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
12367 Discussions
XMP 2400 MHz on Kaby Lake - Warranty
PCzar2
According to I would like to ask if using XMP profile on Kaby Lake CPU but still in officially supported CPU range (2400 MHz) voids user's warranty?
n_scott_pearson
Super User Retired Employee
While Intel technically considers the use of XMP profiles that go above the processor's maximum supported bus speed to be a form of overclocking, this does not void your warranty. Of course, if the system doesn't work while configured for these profiles, don't expect Intel to help you solve this problem. In most cases, this is the fault of the motherboard, not the processor, and Intel isn't going to debug support for individual 3rd-party motherboards.
PCzar2
And what about XMP profile in range of CPU official supported memory clock speed (e.g. 2400 MHz for Kaby Lake)? Is this also considered as overclocking?
n_scott_pearson
If it is within the range of clock speeds that are formally supported, then no, this wouldn't be considered overclocking.
The "over" and "clock" in "overclocking" infer that you are operating some portion of the processor at clock speeds that are above what Intel intended and above what Intel has validated the processor to support without issue. What happens in this case is an unknown. It may work without issue and without any long-term consequences. I may work but have longer-term consequences (for example, thermals-based silicon degradation that shortens the processor's lifetime). It may work but have temporary or permanent short-term consequences (for example, thermal overrun and potentially resulting silicon damage). Finally, it may just not work at all.
I hope I have explained this in terms you will understand.
