Processors
14534 Discussions
XTU I7-8750H settings for ICCMax
LM2
While dropping my core voltage offset to -0.115v, I noticed that the next setting down is:
Processor Core IccMax
it is set at 128.000A, I do not remember if this was the original setting, and how do I determine if this is a default, too high or safe? I do not remember adjusting this myself.
Thanks for reading.
Hello OldShaky2080,
Thank you for joining this community; it will be more than a pleasure to assist you.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
As well, can you please provide us with the Intel (R) XTU version that you are running?
I hope to hear from you soon.
Diego S.
LM2
Thank you for your response.
The XTU version is:
Intel® Extreme Tuning Utility v6.4 Version Number: 6.4.1.23 Release type: MR Release Date: 05 /18/2018
Hello OldShaky2080,
Thank you for your patience.
In this case, if you do not have any special or customized setting on the BIOS , you can access it a load the defaults of the unit, in that way Intel® Extreme Tuning (Intel® XTU) will read the BIOS values and take them back to normal.
Please consider that Intel® XTU tool can be used by any device but it is specially designed for desktop systems, since you own an OEM equipment, we don't really know where the readings are coming from, especially that most of the BIOS setting are coming from system manufacturer and most of the time, are pre-defined.
I hope this helps.
Diego S.
LM2
Thank you.
I will reset the bios to default just in case.
Hello OldShaky2080,
That sounds fine, let us know if you need further assistance, so we can provide you with the right guidance.
I hope this helps.
Diego S.
Hello OldShaky2080,
We just wanted to double check if you still need further assistance.
Please don't hesitate on contacting us back.
Diego S.
