Processors
16133 Discussions
XTU Paired Hotkeys wont allow the use of the 'Home' key despite choosing a different hotkey modifier
KirkH420
How to recreate:
  • Press the "Add Hotkey" button (Profile Pairing Panel)
  • Change Hotkey Modifiers to CONTROL+SHIFT+ALT+HOME
       * This will display a warning "You cannot save this Hotkey-Profile pair:"
          It says "The selected hotkey is already in use" but it is clearly NOT in use!
       * This is despite the fact that the Default Hotkey is set to CONTROL+SHIFT+HOME
Clearly the Hotkey Modifier "CONTROL+SHIFT+ALT+HOME" should be available. There should be no reason it is not available.
Senkuchan
Valued Contributor II
Have you tried reinstalling xtu to check if there’s any changes?
To fully uninstall xtu, you can follow this link: https://www.intel.com/content/www/us/en/support/articles/000032459/processors/processor-utilities-and-programs.html
