Processors
16297 Discussions
XTU Settings Not Preserved After Power Outage
IblisBane
So I realise this is probably working as intended as a safety measure, just wondering if there's a way to get around it...
I finally noticed that if I experience a power outage while my PC is on, my XTU settings revert to default.
Unfortunately it's not an uncommon occurrence where I live, and every time it happens, I have to re-apply my (not extreme) OC settings. (Which I usually forget to do until I'm running something and see my clock speed.)
It's fine if I shut down normally and re-start, but if the power goes out, when I restart I see "Watchdog Failed: True" and settings are reverted.
Any way to force it to keep the settings even after what probably looks like a crash to it?
Jocelyn_Intel
Hello, @IblisBane
Thank you for posting on the Intel® communities.
I am sorry to hear what is happening with your Intel® Extreme Tuning Utility (Intel® XTU), I will gladly assist you here.
Could you please provide us with an Intel® SSU report so we can investigate more about this issue?
Intel® System Support Utility for Windows.
Note: Make sure to mark the box that says "everything" before pressing the Scan button. After that, click on "Next>" and select "Save" and then, attach the .txt file.
Jocelyn M.
Jocelyn_Intel
Hello, @IblisBane
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Jocelyn_Intel
Hello, @IblisBane
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
