Processors
14493 Discussions
XTU Vcore offset adjustment lost after Hyper-V role installed
WillXu
Platform: Intel i5-9600K / MSI B360M Mortar with latest BIOS / 16GB DDR4
OS: Windows Server 2022 version 21H2 20348.350
i've represent the issue by follow steps:
1. format hdd then newly install Windows Server 2022
2. install drivers: intel chipset + Intel vga driver + intel ME
3. install XTU_6.4.1.25
4. reboot
5. start XTU,  confirmed all function is ok, include Vcore offset adjustment, i can use xtucli to tuning the vcore offset value with id 34
6. add windows feature, only add Hyper-V role, then reboot
7.start XTU, i found Vcore offset adjustment function lost,then i use xtucli -i tuning, i found id 34 is gone!
C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Client>xtucli -i tuning
48 Turbo Boost Power Max 115W 1.000 4095.875 0.125 7994
47 Turbo Boost Short Power Max 125W 1.000 4095.875 0.125 7994
49 Turbo Boost Short Power Max Enable 1 0 1 1 2
66 Turbo Boost Power Time Window 28Seconds 0.25 96.0 0.062 35
110 1 0 1 1 2
80 Overclocking Lock 1 0 1 1 2
50 Package Turbo Power Lock 0 0 1 1 2
41 Enhanced Intel? SpeedStep Technology 1 0 1 1 2
26 Intel? Turbo Boost Technology 1 0 1 1 2
88 Core Voltage Mode 0.0 0.0 1.0 1.0 2
82 Processor Graphics Voltage Mode 0.0 0.0 1.0 1.0 2
104 Processor Graphics IccMax 255.750A 1.000 255.750 0.250 1020
78 Cache Voltage Mode 0.0 0.0 1.0 1.0 2
106 Cache IccMax 255.750A 1.000 255.750 0.250 1020
105 Processor Graphics Unslice IccMax 255.750A 1.000 255.750 0.250 1020
98 Processor Graphics Media Voltage Mode 0.0 0.0 1.0 1.0 2
250 1.0 0.0 1.0 1.0 2
114 AVX Ratio Offset 31.0x 0.0 31.0 1.0 32
29 1 Active Core 46x 8 255 1 248
30 2 Active Cores 45x 8 255 1 248
31 3 Active Cores 45x 8 255 1 248
32 4 Active Cores 44x 8 255 1 248
42 5 Active Cores 44x 8 255 1 248
43 6 Active Cores 43x 8 255 1 248
3489660933 Processor Core Ratio 43x 8 255 1 248
116 Core 0 255x 8 255 1 248
117 Core 1 255x 8 255 1 248
118 Core 2 255x 8 255 1 248
119 Core 3 255x 8 255 1 248
120 Core 4 255x 8 255 1 248
121 Core 5 255x 8 255 1 248
76 Processor Cache Ratio 46x 8 255 1 248
59 Processor Graphics Ratio Limit 127.5x 0.0 127.5 0.5 256
then i tried to update to xtu 7.5.3.3, the issue is the same
logs from XTU 6.4.1.25 attached
AndrewG_Intel
Hello @WillXu
We found that you have another thread describing the same issue and the same hardware/software environment as this one and Intel Technical Support is already assisting you through that other thread. Therefore, we will close this thread to avoid duplication of efforts.
We will continue working on this one: "XTU Vcore offset adjustment lost after Hyper-V role installed".
Andrew G.
