Processors
16283 Discussions
XTU Vcore offset adjustment lost after Hyper-V role installed
WillXu
Platform: Intel i5-9600K / MSI B360M Mortar with latest BIOS / 16GB DDR4
OS: Windows Server 2022 version 21H2 20348.350
i've represent the issue by follow steps:
1. format hdd then newly install Windows Server 2022
2. install drivers: intel chipset + Intel vga driver + intel ME
3. install XTU_6.4.1.25
4. reboot
5. start XTU,  confirmed all function is ok, include Vcore offset adjustment, i can use xtucli to tuning the vcore offset value with id 34
6. add windows feature, only add Hyper-V role, then reboot
7.start XTU, i found Vcore offset adjustment function lost,then i use xtucli -i tuning, i found id 34 is gone!
xtucli -i tuning result as below
48 Turbo Boost Power Max 115W 1.000 4095.875 0.125 7994
47 Turbo Boost Short Power Max 125W 1.000 4095.875 0.125 7994
49 Turbo Boost Short Power Max Enable 1 0 1 1 2
66 Turbo Boost Power Time Window 28Seconds 0.25 96.0 0.062 35
110 1 0 1 1 2
80 Overclocking Lock 1 0 1 1 2
50 Package Turbo Power Lock 0 0 1 1 2
41 Enhanced Intel? SpeedStep Technology 1 0 1 1 2
26 Intel? Turbo Boost Technology 1 0 1 1 2
88 Core Voltage Mode 0.0 0.0 1.0 1.0 2
82 Processor Graphics Voltage Mode 0.0 0.0 1.0 1.0 2
104 Processor Graphics IccMax 255.750A 1.000 255.750 0.250 1020
78 Cache Voltage Mode 0.0 0.0 1.0 1.0 2
106 Cache IccMax 255.750A 1.000 255.750 0.250 1020
105 Processor Graphics Unslice IccMax 255.750A 1.000 255.750 0.250 1020
98 Processor Graphics Media Voltage Mode 0.0 0.0 1.0 1.0 2
250 1.0 0.0 1.0 1.0 2
114 AVX Ratio Offset 31.0x 0.0 31.0 1.0 32
29 1 Active Core 46x 8 255 1 248
30 2 Active Cores 45x 8 255 1 248
31 3 Active Cores 45x 8 255 1 248
32 4 Active Cores 44x 8 255 1 248
42 5 Active Cores 44x 8 255 1 248
43 6 Active Cores 43x 8 255 1 248
3489660933 Processor Core Ratio 43x 8 255 1 248
116 Core 0 255x 8 255 1 248
117 Core 1 255x 8 255 1 248
118 Core 2 255x 8 255 1 248
119 Core 3 255x 8 255 1 248
120 Core 4 255x 8 255 1 248
121 Core 5 255x 8 255 1 248
76 Processor Cache Ratio 46x 8 255 1 248
59 Processor Graphics Ratio Limit 127.5x 0.0 127.5 0.5 256
then i tried to update to xtu 7.5.3.3, the issue is the same
Alberto_R_Intel
WillXu, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new computer?
When did you purchase it?
Was the Vcore offset adjustment feature working fine before on this same machine?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
WillXu
Is this a new computer? When did you purchase it?
i purchased this computer at March this year. Whole new.
No, without any HW changes. Just reinstall the OS from Windows Server 2019 to 2022 then the issue happened.
In order to confirm the issue, i tried to reinstall the system to Server 2019, the Vcore works! Then I tried to install Server 2022 again with the steps as I discribed above, the Vcore lost ONLY with HyperV installed!
When i removed HyperV, Vcore did appeared again!
so I think maybe Hyper-V role blocked the Vcore adjustment on Windows Server 2022.
the log attached is the log when I installed Windows 2022+ XTU, then add HyperV role
WillXu
SSU Log with 3rd Party s/w logs attached
WillXu
XTU version 6.4.1.25 installed, and the snapshot below captured after Hyper-V installed.
then i tried to update to xtu 7.5.3.3,  the issue is the same, still no Vcore adjustment
Alberto_R_Intel
WillXu, Thank you very much for providing that information, the SSU report, and the pictures.
According to the SSU document, the operating system version being used, as you mentioned, is Microsoft Windows Server 2022 Datacenter / 10.0.20348 Build 20348. It is important to notice that under the list of validated OS for the Intel® XTU, the Windows* Server is not showing as you can confirm here:
https://www.intel.com/content/www/us/en/download/17881/intel-extreme-tuning-utility-intel-xtu.html?wapkw=xtu
https://downloadmirror.intel.com/29183/XTU-7.5.3.3-ReleaseNotes.pdf
Since you also stated that it was working fine previously while using Windows Server 2019 and that OS is not showing on the list either, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
WillXu
I installed XTU on Server 2019 (with HyperV and container role) and it was working fine, and after upgraded to Server 2022, Vcore lost.
I'm worrying about other softwares installed on system might conflict with Vcore,  I setup a whole new Windows 2022 System during the test, and wrote down the steps, and I found that issue can be reproduced with the steps, after Vcore lost, i tried to remove HyperV, Vcore appeared.
so I Confirmed that XTU is working fine on Server 2022 WITHOUT Hyper-V role installed, OR Hyper-V REMOVED
I mentioned someone has the same issue on Windows 11 with Hyper-V installed, their recovery method is the same, just removing Hyper-V role and all other virtualization function such as container, and the Vcore adj will be back after system restart.
so i think that virtualization roles might conflict with Vcore both on Windows 11/ Windows Server 2022, and no matter version 6.4.1.25 or 7.5.3.3
btw, old XTU with CLI is very convience for management-automation, hope Intel will add CLI to newer version of XTU
Alberto_R_Intel
Hello WillXu, I just wanted to let you know that we are still working on your case and waiting for updates. Thank you very much.
Albert R.
WillXu
Alberto_R_Intel
Hello WillXu, I just received an update on this matter.
We tried to reproduce the issue in our Intel® lab using Windows* 11. Enabling Hyper-V did not delete the settings applied to the Vcore Offset in the Intel® XTU (7.5.3.3), please see the video attached and let us know if we are missing any steps.
Albert R.
WillXu
the difference:
  1. I reproduced the issue on Windows Server 2022 version 21H2 20348.350. I never tried it on Windows 11 myself
  2. on the clean Server 2022, after installed intel chipset + Intel vga driver + intel ME, I installed XTU 6.4.1.25 then add Hyper-V role to reproduce the issue.
    after the issue reproduced, i mean the Vcore Offset lost, then I uninstall XTU 6.4.1.25 and install XTU 7.5.3.3. I never tried to install XTU7.5.3.3 directly on the 2022 after the OS clean installed. maybe files left behind by 6.4.1.25 disturbed the XTU 7.5.3.3?
btw:
Alberto_R_Intel
WillXu, Thank you very much for letting us know those details.
Yes, the thing is that Microsoft Windows Server 2022 is not validated as officially supported by Intel® XTU, so, any discrepancies will be expected while using a not supported OS.
"I never tried to install XTU7.5.3.3 directly on the 2022 after the OS clean installed. maybe files left behind by 6.4.1.25 disturbed the XTU 7.5.3.3?", yes, that could be the reason why it is not working as expected and something that you can try in order try to fix this problem. Still, we recommend to use Intel® XTU with a supported OS:
Albert R.
WillXu
I use version 6.4.1.25 in order to get the CLI for management automation
Alberto_R_Intel
WillXu, Thank you very much for clarifying those details.
In this case, the thing is that the problem is related to the Operating System being used that is not supported by the tool, the issue is not regarding the Intel® XTU itself as you can confirm in the results of our Intel® lab.
Albert R.
