Hello Mscapini,
This file is normally capable to be exported to Excel. In order to have a better understanding of your issue, please provide me with the following:
Do you receive any error messages when you tried to export the files?
What is the CPU model you have?
Jean O.
Hello Mscapini,
Thanks for your response
I understand that the issue is that the imported file shows a different report than the original, as an example, you mentioned that the fields, which should be 14 are a completely different number. However, I overlooked both files you shared and I did not notice a mismatch between both reports (original and imported). Could you be more specific as to which column fields are the error located at?
Jean O.
One is the import of the other and so they are both wrong !
The issue is that the imported values are not aligned with the column headers and that the misalignement can be different on different rows.
For example, take the first data row.
The actual CPU load is 0,7557.
0 is imported in the first column, 7557 in the second, as if it was the Memory util (which is not).
In the 8th data row, instead, the CPU load is 100 and does not have decimals, so it is imported correctly. So is Mem. But Package Temp is 51,1595 and is imported in two different columns.
Core Voltage is 0.801. 0 is imported in Max Core Freq, 801 in Max Core Count.
Does these data make some sense to you reported in this way ?
Hope it now more clear
Hello Mscapini,
Jean O.
Hello Mscapini,
Thanks for waiting for a response.
I am still researching this matter; however, to continue to further, could you provide me with the XTU version you are running?
Jean O.
Hello Mscapini,
Thanks for your prompt response.
I will now resume researching this matter. I will post back once I have more details.
Jean O.
Hello Mscapini,
We have tried XTU (7.9.1.3) & 7.9.0.24 versions but we couldn't find any unusual data, and so far, we do not have reports of other users reporting this type of issue. However, we would suggest you check Excel settings:
- Select Data > Text to Columns. In the Convert Text to Columns Wizard, select Delimited > Next. Select the Delimiters for your data. For example, tab and/or Space
- Also on Excel options > advance> use system separators select dot separate decimals
Finally, if the issue persists. We suggest you remove and reinstall XTU to restore the defaults on the configuration.
- Uninstall the Intel® Extreme Tuning Utility.
- Use the Windows* 10 Apps and Features.
- Search for Intel® Extreme Tuning Utility.
- Click Uninstall.
- Open the Task Manager.
- Check under Processes for XtuService.
- If found, click End Task.
- Download and install the Intel® XTU application.
Jean O.
Hello Mscapini,
I hope you are doing fine.
Jean O.
Hello Mscapini,
It's unfortunate that you decided to stop using the XTU tool, however, I understand your position.
Since you are no longer using our tool, I will continue to close the thread. If you need additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
