Processors
14970 Discussions
XTU on Surface Pro 3 crashes
TLink
When I got the SP3, the first thing I wanted to do was to undervolt with xtu-problem is now that every minimal change on voltage offset and even going back to default setting causes a reboot when entering standby mode.
So do you guys know how to fix this???-Thanks in advance
Silvia_L_Intel1
MotoXpert, I'm sorry about this situation, but it is important to know that Intel® Extreme Tuning Utility (XTU) was design to work on Intel motherboards only, not on OEM or other system brands devices.
If you still want to use the utility, you may want to use an older version of the software.
If it still not working, you may check if you can restore your computer to the last working state by choosing "System Restore" once you're in Windows.
