I've been trying for hours to get XTU to work again, and continue to get "Unable to start Intel Extreme Tuning Utility. If there is another performance tuning application running, you must close it before trying to start this application". Does anyone have any advice on how to resolve this?
Windows 10 64bit
Dell Venue 11 Pro 7130 MS
Intel Core i5-4210Y CPU @ 1.50Ghz
Intially, it didn't work, but after searching some forums, I then uninstalled and re-installed which did the trick. Subsequent reboots then wouldn't work and I'm not sure why.
It's a relatively fresh copy of Windows 10 with Dell Command driver updates. As far as I'm aware, there's no other performance tuning software installed.
Any advice will be appreciated.
Thank you!
XTU does not support your processor. Only X and K processors are supported.
Doc
That's odd. I've managed to run it a handful of times and other forums mention they've used it.
Try doing this:
- Uninstall XTU.
- If it didn't automatically reboot at the end of Step 1, reboot now.
- Reboot a second time.
- Install XTU.
Hope this helps,
Thanks for the advice. I've tried it few times already and unfortunately it didn't work.
- Uninstall
- Restart
- Restart
- Reinstall
- Restart - waited for XTU to auto load and error occurs
- Restart again - same result
- Uninstalled
- Restart
- Restart
- Reinstall
- Restart - same result
I'm really curious if there is a software that is conflicting, but I'm not sure what it is following a fresh Win 10 install and Dell driver updates.
The only thing unusual is that on reboot, Task Manager > Services > XTU3SERVICE has a status of "starting" and stays that way... Is this normal?
I'm not sure what's changed, but after leaving it uninstalled for a week, I reinstalled, restarted and it loaded automatically on reboot.
I then applied the settings gradually which seemed to have worked.
The benchmark is published here: https://hwbot.org/submission/4292634_vampypang_xtu_core_i5_4210y_230_marks
I've since rebooted the laptop but can't reload XTU as I get the same error as mentioned in the original post.
To check if the settings are still applied, I use HWiNFO and CPU-Z.
I would much prefer to get XTU opening when I want, but it's still a mystery why it's so intermittent and only opens about 5% of the time...!
Again, XTU does not support your processor. Only X and K processors are supported.
Doc
