17295 Discussions
XTU will not install - Error code 0x80070643
Wyllow
I had XTU installed on my system previously. Then I had an update at the top of the screen telling me to update to the newest version. I tried that and the update failed. It would not open again and I did a full uninstall. (removed all the Intel folders in Program data and files as well as uninstalling the file.)
I am trying to install the newest version 7.14.2.14 and the below screen keeps happening and then the error message.
I am running this program as Administrator.
Any help would be greatly appreciated.
Here is the logs.
[46E0:09A4][2024-08-21T18:27:06]i001: Burn v3.14.1.8722, Windows v10.0 (Build 22631: Service Pack 0), path: C:\Windows\Temp\{2CDF2479-75F9-4B2D-9901-8E7DE705C96B}\.cr\XTUSetup_7.14.2.14.exe
[46E0:09A4][2024-08-21T18:27:06]i000: Initializing string variable 'RemoveAllDataCheckboxValue' to value '[RemoveAllDataCheckbox]'
[46E0:09A4][2024-08-21T18:27:06]i000: Initializing version variable 'BundleVersionNumber' to value '7.14.2.14'
[46E0:09A4][2024-08-21T18:27:06]i009: Command Line: '-burn.clean.room=C:\Users\cyrus\Downloads\XTUSetup_7.14.2.14.exe -burn.filehandle.attached=760 -burn.filehandle.self=764'
[46E0:09A4][2024-08-21T18:27:06]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\cyrus\Downloads\XTUSetup_7.14.2.14.exe'
[46E0:09A4][2024-08-21T18:27:06]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\cyrus\Downloads\'
[46E0:09A4][2024-08-21T18:27:06]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821182706.log'
[46E0:09A4][2024-08-21T18:27:06]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[46E0:09A4][2024-08-21T18:27:06]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Extreme Tuning Utility'
[46E0:09A4][2024-08-21T18:27:06]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[46E0:A578][2024-08-21T18:27:07]i000: Setting version variable 'WixBundleFileVersion' to value '7.14.2.14'
[46E0:09A4][2024-08-21T18:27:07]i100: Detect begin, 2 packages
[46E0:09A4][2024-08-21T18:27:07]i000: Product or related product not found: {823C3D41-1C6E-4ECA-9923-1200278AE478}
[46E0:09A4][2024-08-21T18:27:07]i000: Setting version variable 'MsiAlreadyInstalledVersion' to value '0.0.0.0'
[46E0:09A4][2024-08-21T18:27:07]i000: Setting string variable 'NETFRAMEWORK45' to value '533320'
[46E0:09A4][2024-08-21T18:27:07]i000: Setting version variable 'WindowsDllVersion' to value '10.0.22621.3810'
[46E0:09A4][2024-08-21T18:27:07]i101: Detected package: vcredist_64.exe, state: Absent, cached: None
[46E0:09A4][2024-08-21T18:27:07]i101: Detected package: Intel_XtuInstaller.msi, state: Absent, cached: None
[46E0:09A4][2024-08-21T18:27:07]i052: Condition 'BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5' evaluates to true.
[46E0:09A4][2024-08-21T18:27:07]i052: Condition 'WixBundleInstalled OR WindowsDllVersion >= "10.0.14393.0" OR NOT WixBundleAction = 5' evaluates to true.
[46E0:09A4][2024-08-21T18:27:07]i052: Condition 'WixBundleInstalled OR NOT WixBundleAction = 5 OR NETFRAMEWORK45 >= 528040' evaluates to true.
[46E0:09A4][2024-08-21T18:27:07]i199: Detect complete, result: 0x0
[46E0:A578][2024-08-21T18:27:09]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[46E0:09A4][2024-08-21T18:27:09]i200: Plan begin, 2 packages, action: Install
[46E0:09A4][2024-08-21T18:27:09]w321: Skipping dependency registration on package with no dependency providers: vcredist_64.exe
[46E0:09A4][2024-08-21T18:27:09]i000: Setting string variable 'WixBundleLog_vcredist_64.exe' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821182706_000_vcredist_64.exe.log'
[46E0:09A4][2024-08-21T18:27:09]i000: Setting string variable 'WixBundleRollbackLog_vcredist_64.exe' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821182706_000_vcredist_64.exe_rollback.log'
[46E0:09A4][2024-08-21T18:27:09]i000: Setting string variable 'WixBundleRollbackLog_Intel_XtuInstaller.msi' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821182706_001_Intel_XtuInstaller.msi_rollback.log'
[46E0:09A4][2024-08-21T18:27:09]i000: Setting string variable 'WixBundleLog_Intel_XtuInstaller.msi' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821182706_001_Intel_XtuInstaller.msi.log'
[46E0:09A4][2024-08-21T18:27:09]i201: Planned package: vcredist_64.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: None
[46E0:09A4][2024-08-21T18:27:09]i201: Planned package: Intel_XtuInstaller.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[46E0:09A4][2024-08-21T18:27:09]i299: Plan complete, result: 0x0
[46E0:09A4][2024-08-21T18:27:09]i300: Apply begin
[46E0:09A4][2024-08-21T18:27:09]i010: Launching elevated engine process.
[46E0:09A4][2024-08-21T18:27:09]i011: Launched elevated engine process.
[46E0:09A4][2024-08-21T18:27:09]i012: Connected to elevated engine.
[B7A8:8980][2024-08-21T18:27:09]i358: Pausing automatic updates.
[B7A8:8980][2024-08-21T18:27:09]i359: Paused automatic updates.
[B7A8:8980][2024-08-21T18:27:09]i360: Creating a system restore point.
[B7A8:8980][2024-08-21T18:27:09]i361: Created a system restore point.
[B7A8:8980][2024-08-21T18:27:09]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, options: 0x7, disable resume: No
[B7A8:8980][2024-08-21T18:27:09]i000: Caching bundle from: 'C:\Windows\Temp\{965FF05A-FAFF-4C36-BA37-9A963195E5D7}\.be\XTUUISetup.exe' to: 'C:\ProgramData\Package Cache\{fdc445a5-0180-47a6-a653-ab97fa2d4723}\XTUUISetup.exe'
[B7A8:8980][2024-08-21T18:27:09]i320: Registering bundle dependency provider: {fdc445a5-0180-47a6-a653-ab97fa2d4723}, version: 7.14.2.14
[B7A8:8980][2024-08-21T18:27:09]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, resume: Active, restart initiated: No, disable resume: No
[B7A8:13AC][2024-08-21T18:27:09]i305: Verified acquired payload: vcredist_64.exe at path: C:\ProgramData\Package Cache\.unverified\vcredist_64.exe, moving to: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe.
[B7A8:13AC][2024-08-21T18:27:10]i305: Verified acquired payload: Intel_XtuInstaller.msi at path: C:\ProgramData\Package Cache\.unverified\Intel_XtuInstaller.msi, moving to: C:\ProgramData\Package Cache\{B3768C84-139F-4A71-A175-A2A85F4712DE}v7.14.2.14\Intel_XtuInstaller.msi.
[B7A8:8980][2024-08-21T18:27:10]i301: Applying execute package: vcredist_64.exe, action: Install, path: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe, arguments: '"C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe" /install /quiet /norestart'
[B7A8:8980][2024-08-21T18:27:10]e000: Error 0x80070666: Process returned error: 0x666
[B7A8:8980][2024-08-21T18:27:10]e000: Error 0x80070666: Failed to execute EXE package.
[46E0:09A4][2024-08-21T18:27:10]e000: Error 0x80070666: Failed to configure per-machine EXE package.
[46E0:09A4][2024-08-21T18:27:10]w350: Applied non-vital package: vcredist_64.exe, encountered error: 0x80070666. Continuing...
[B7A8:8980][2024-08-21T18:27:10]i323: Registering package dependency provider: {B3768C84-139F-4A71-A175-A2A85F4712DE}, version: 7.14.2.14, package: Intel_XtuInstaller.msi
[B7A8:8980][2024-08-21T18:27:10]i301: Applying execute package: Intel_XtuInstaller.msi, action: Install, path: C:\ProgramData\Package Cache\{B3768C84-139F-4A71-A175-A2A85F4712DE}v7.14.2.14\Intel_XtuInstaller.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" REMOVEALLAPPDATA=""'
[B7A8:8980][2024-08-21T18:27:11]e000: Error 0x80070643: Failed to install MSI package.
[B7A8:8980][2024-08-21T18:27:11]e000: Error 0x80070643: Failed to execute MSI package.
[46E0:09A4][2024-08-21T18:27:11]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[46E0:09A4][2024-08-21T18:27:11]i319: Applied execute package: Intel_XtuInstaller.msi, result: 0x80070643, restart: None
[46E0:09A4][2024-08-21T18:27:11]e000: Error 0x80070643: Failed to execute MSI package.
[B7A8:8980][2024-08-21T18:27:11]i318: Skipped rollback of package: Intel_XtuInstaller.msi, action: Uninstall, already: Absent
[46E0:09A4][2024-08-21T18:27:11]i319: Applied rollback package: Intel_XtuInstaller.msi, result: 0x0, restart: None
[B7A8:8980][2024-08-21T18:27:11]i329: Removed package dependency provider: {B3768C84-139F-4A71-A175-A2A85F4712DE}, package: Intel_XtuInstaller.msi
[B7A8:8980][2024-08-21T18:27:11]i351: Removing cached package: Intel_XtuInstaller.msi, from path: C:\ProgramData\Package Cache\{B3768C84-139F-4A71-A175-A2A85F4712DE}v7.14.2.14\
[B7A8:8980][2024-08-21T18:27:11]i301: Applying rollback package: vcredist_64.exe, action: Uninstall, path: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe, arguments: '"C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe" /uninstall /quiet /norestart'
[46E0:09A4][2024-08-21T18:27:12]i319: Applied rollback package: vcredist_64.exe, result: 0x0, restart: None
[B7A8:8980][2024-08-21T18:27:12]i351: Removing cached package: vcredist_64.exe, from path: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\
[B7A8:8980][2024-08-21T18:27:12]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, resume: None, restart: None, disable resume: No
[B7A8:8980][2024-08-21T18:27:12]i330: Removed bundle dependency provider: {fdc445a5-0180-47a6-a653-ab97fa2d4723}
[B7A8:8980][2024-08-21T18:27:12]i352: Removing cached bundle: {fdc445a5-0180-47a6-a653-ab97fa2d4723}, from path: C:\ProgramData\Package Cache\{fdc445a5-0180-47a6-a653-ab97fa2d4723}\
[B7A8:8980][2024-08-21T18:27:12]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, resume: None, restart initiated: No, disable resume: No
[46E0:09A4][2024-08-21T18:27:12]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
Wyllow
Here is the log that came with that failure.
[83B4:83B0][2024-08-21T17:55:37]i001: Burn v3.14.1.8722, Windows v10.0 (Build 22631: Service Pack 0), path: C:\Windows\Temp\{0EE1A49F-1F26-453C-9C93-50C54AD558C3}\.cr\XTUSetup_7.14.2.14(1).exe
[83B4:83B0][2024-08-21T17:55:37]i000: Initializing string variable 'RemoveAllDataCheckboxValue' to value '[RemoveAllDataCheckbox]'
[83B4:83B0][2024-08-21T17:55:37]i000: Initializing version variable 'BundleVersionNumber' to value '7.14.2.14'
[83B4:83B0][2024-08-21T17:55:37]i009: Command Line: '-burn.clean.room=C:\Users\cyrus\Downloads\XTUSetup_7.14.2.14(1).exe -burn.filehandle.attached=784 -burn.filehandle.self=792'
[83B4:83B0][2024-08-21T17:55:37]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\cyrus\Downloads\XTUSetup_7.14.2.14(1).exe'
[83B4:83B0][2024-08-21T17:55:37]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\cyrus\Downloads\'
[83B4:83B0][2024-08-21T17:55:37]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821175537.log'
[83B4:83B0][2024-08-21T17:55:37]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[83B4:83B0][2024-08-21T17:55:37]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Extreme Tuning Utility'
[83B4:83B0][2024-08-21T17:55:37]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[83B4:8FE0][2024-08-21T17:55:37]i000: Setting version variable 'WixBundleFileVersion' to value '7.14.2.14'
[83B4:83B0][2024-08-21T17:55:37]i100: Detect begin, 2 packages
[83B4:83B0][2024-08-21T17:55:37]i000: Product or related product not found: {823C3D41-1C6E-4ECA-9923-1200278AE478}
[83B4:83B0][2024-08-21T17:55:37]i000: Setting version variable 'MsiAlreadyInstalledVersion' to value '0.0.0.0'
[83B4:83B0][2024-08-21T17:55:37]i000: Setting string variable 'NETFRAMEWORK45' to value '533320'
[83B4:83B0][2024-08-21T17:55:37]i000: Setting version variable 'WindowsDllVersion' to value '10.0.22621.3810'
[83B4:83B0][2024-08-21T17:55:37]i101: Detected package: vcredist_64.exe, state: Absent, cached: None
[83B4:83B0][2024-08-21T17:55:37]i101: Detected package: Intel_XtuInstaller.msi, state: Absent, cached: None
[83B4:83B0][2024-08-21T17:55:37]i052: Condition 'BundleVersionNumber > MsiAlreadyInstalledVersion OR BundleVersionNumber = "0.0.0.0" OR NOT WixBundleAction = 5' evaluates to true.
[83B4:83B0][2024-08-21T17:55:37]i052: Condition 'WixBundleInstalled OR WindowsDllVersion >= "10.0.14393.0" OR NOT WixBundleAction = 5' evaluates to true.
[83B4:83B0][2024-08-21T17:55:37]i052: Condition 'WixBundleInstalled OR NOT WixBundleAction = 5 OR NETFRAMEWORK45 >= 528040' evaluates to true.
[83B4:83B0][2024-08-21T17:55:37]i199: Detect complete, result: 0x0
[83B4:8FE0][2024-08-21T17:55:39]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[83B4:83B0][2024-08-21T17:55:39]i200: Plan begin, 2 packages, action: Install
[83B4:83B0][2024-08-21T17:55:39]w321: Skipping dependency registration on package with no dependency providers: vcredist_64.exe
[83B4:83B0][2024-08-21T17:55:39]i000: Setting string variable 'WixBundleLog_vcredist_64.exe' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821175537_000_vcredist_64.exe.log'
[83B4:83B0][2024-08-21T17:55:39]i000: Setting string variable 'WixBundleRollbackLog_vcredist_64.exe' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821175537_000_vcredist_64.exe_rollback.log'
[83B4:83B0][2024-08-21T17:55:39]i000: Setting string variable 'WixBundleRollbackLog_Intel_XtuInstaller.msi' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821175537_001_Intel_XtuInstaller.msi_rollback.log'
[83B4:83B0][2024-08-21T17:55:39]i000: Setting string variable 'WixBundleLog_Intel_XtuInstaller.msi' to value 'C:\Users\cyrus\AppData\Local\Temp\Intel(R)_Extreme_Tuning_Utility_20240821175537_001_Intel_XtuInstaller.msi.log'
[83B4:83B0][2024-08-21T17:55:39]i201: Planned package: vcredist_64.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: None
[83B4:83B0][2024-08-21T17:55:39]i201: Planned package: Intel_XtuInstaller.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[83B4:83B0][2024-08-21T17:55:39]i299: Plan complete, result: 0x0
[83B4:83B0][2024-08-21T17:55:39]i300: Apply begin
[83B4:83B0][2024-08-21T17:55:39]i010: Launching elevated engine process.
[83B4:83B0][2024-08-21T17:55:39]i011: Launched elevated engine process.
[83B4:83B0][2024-08-21T17:55:39]i012: Connected to elevated engine.
[7DAC:8C68][2024-08-21T17:55:39]i358: Pausing automatic updates.
[7DAC:8C68][2024-08-21T17:55:39]i359: Paused automatic updates.
[7DAC:8C68][2024-08-21T17:55:39]i360: Creating a system restore point.
[7DAC:8C68][2024-08-21T17:55:39]i361: Created a system restore point.
[7DAC:8C68][2024-08-21T17:55:39]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, options: 0x7, disable resume: No
[7DAC:8C68][2024-08-21T17:55:39]i000: Caching bundle from: 'C:\Windows\Temp\{2DD4497D-367E-4B8F-AC6C-F77DB074EF08}\.be\XTUUISetup.exe' to: 'C:\ProgramData\Package Cache\{fdc445a5-0180-47a6-a653-ab97fa2d4723}\XTUUISetup.exe'
[7DAC:8C68][2024-08-21T17:55:39]i320: Registering bundle dependency provider: {fdc445a5-0180-47a6-a653-ab97fa2d4723}, version: 7.14.2.14
[7DAC:8C68][2024-08-21T17:55:39]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, resume: Active, restart initiated: No, disable resume: No
[7DAC:6EEC][2024-08-21T17:55:39]i305: Verified acquired payload: vcredist_64.exe at path: C:\ProgramData\Package Cache\.unverified\vcredist_64.exe, moving to: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe.
[7DAC:6EEC][2024-08-21T17:55:40]i305: Verified acquired payload: Intel_XtuInstaller.msi at path: C:\ProgramData\Package Cache\.unverified\Intel_XtuInstaller.msi, moving to: C:\ProgramData\Package Cache\{B3768C84-139F-4A71-A175-A2A85F4712DE}v7.14.2.14\Intel_XtuInstaller.msi.
[7DAC:8C68][2024-08-21T17:55:40]i301: Applying execute package: vcredist_64.exe, action: Install, path: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe, arguments: '"C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe" /install /quiet /norestart'
[7DAC:8C68][2024-08-21T17:55:40]e000: Error 0x80070666: Process returned error: 0x666
[7DAC:8C68][2024-08-21T17:55:40]e000: Error 0x80070666: Failed to execute EXE package.
[83B4:83B0][2024-08-21T17:55:40]e000: Error 0x80070666: Failed to configure per-machine EXE package.
[83B4:83B0][2024-08-21T17:55:40]w350: Applied non-vital package: vcredist_64.exe, encountered error: 0x80070666. Continuing...
[7DAC:8C68][2024-08-21T17:55:40]i323: Registering package dependency provider: {B3768C84-139F-4A71-A175-A2A85F4712DE}, version: 7.14.2.14, package: Intel_XtuInstaller.msi
[7DAC:8C68][2024-08-21T17:55:40]i301: Applying execute package: Intel_XtuInstaller.msi, action: Install, path: C:\ProgramData\Package Cache\{B3768C84-139F-4A71-A175-A2A85F4712DE}v7.14.2.14\Intel_XtuInstaller.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" REMOVEALLAPPDATA=""'
[7DAC:8C68][2024-08-21T17:55:42]e000: Error 0x80070643: Failed to install MSI package.
[7DAC:8C68][2024-08-21T17:55:42]e000: Error 0x80070643: Failed to execute MSI package.
[83B4:83B0][2024-08-21T17:55:42]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[83B4:83B0][2024-08-21T17:55:42]i319: Applied execute package: Intel_XtuInstaller.msi, result: 0x80070643, restart: None
[83B4:83B0][2024-08-21T17:55:42]e000: Error 0x80070643: Failed to execute MSI package.
[7DAC:8C68][2024-08-21T17:55:42]i318: Skipped rollback of package: Intel_XtuInstaller.msi, action: Uninstall, already: Absent
[83B4:83B0][2024-08-21T17:55:42]i319: Applied rollback package: Intel_XtuInstaller.msi, result: 0x0, restart: None
[7DAC:8C68][2024-08-21T17:55:42]i329: Removed package dependency provider: {B3768C84-139F-4A71-A175-A2A85F4712DE}, package: Intel_XtuInstaller.msi
[7DAC:8C68][2024-08-21T17:55:42]i351: Removing cached package: Intel_XtuInstaller.msi, from path: C:\ProgramData\Package Cache\{B3768C84-139F-4A71-A175-A2A85F4712DE}v7.14.2.14\
[7DAC:8C68][2024-08-21T17:55:42]i301: Applying rollback package: vcredist_64.exe, action: Uninstall, path: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe, arguments: '"C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\vcredist_64.exe" /uninstall /quiet /norestart'
[83B4:83B0][2024-08-21T17:55:42]i319: Applied rollback package: vcredist_64.exe, result: 0x0, restart: None
[7DAC:8C68][2024-08-21T17:55:42]i351: Removing cached package: vcredist_64.exe, from path: C:\ProgramData\Package Cache\AE97F1E35C50A3C1B7B231995AD547828E71FE4C\
[7DAC:8C68][2024-08-21T17:55:42]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, resume: None, restart: None, disable resume: No
[7DAC:8C68][2024-08-21T17:55:42]i330: Removed bundle dependency provider: {fdc445a5-0180-47a6-a653-ab97fa2d4723}
[7DAC:8C68][2024-08-21T17:55:42]i352: Removing cached bundle: {fdc445a5-0180-47a6-a653-ab97fa2d4723}, from path: C:\ProgramData\Package Cache\{fdc445a5-0180-47a6-a653-ab97fa2d4723}\
[7DAC:8C68][2024-08-21T17:55:42]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fdc445a5-0180-47a6-a653-ab97fa2d4723}, resume: None, restart initiated: No, disable resume: No
[83B4:83B0][2024-08-21T17:55:42]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
JedG_Intel
Hello Wyllow,
Thank you for posting at Intel Community Forum
Upon checking, I can see that you have contacted us via chat about this concern. Please let us know how you would like us to continue assisting you, via chat or community?
We hope to hear from you soon!
Jed G.
JedG_Intel
Hello Wyllow,
I wanted to check if you had the chance to review the information that I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
Wyllow
I apologize, I have not been around the last few days. I actually got my CPU RMA'd through the company I ordered it from.
I have the new CPU installed, but XTU will not install still. It still says unsupported platform with the new CPU.
Can you assist?
AlHill
What is the model number of your processor?
[If you find any Intel driver you might need, download and save it now.]
Wyllow
14900ks
Additionally, when I try to install the below software, I get this error.
Intel® Arc™ & Iris® Xe Graphics - Windows*
AlHill
What are your video settings in the bios?
Do you have an add-on videlo card?
Is the bios updated?
Wyllow
I am on the most up to date ASUS BIOS.
Specs:
Case: HYTE Y70 RGB Gaming Case - White
Motherboard
: ASUS ROG Maximus Z790 Dark Hero - BIOS VERSION 1503
CPU
: Intel® Core™ i9-14900KS
GPU
: NVIDIA GeForce RTX 4090 - 24GB GDDR6X - ASUS TUF GAMING OC Edition
Ram
: 32 GB [16 GB X2] DDR5-7200MHz CORSAIR Dominator Titanium
What video settings are you referring to? I can take a look but I do not know them off hand.
AlHill
In the bios, is the integrated graphics enabled?  You should be able to have both your nvidia and intel graphics enabled.
When the OS is up, in the device manager, do you see both graphics?
Wyllow
No, I only see the 4090.
Would this show other than in the "Display Adapters" section? I will check the BIOS now to see if I can turn on Intel Graphics, if you recommend it?
AlHill
There could be something under "other devices".
Did you install the chipset inf?
Let's see what your bios says.
Wyllow
When trying to install "Chipset INF" I get this error.
This is what shows in Other Devices.
AlHill
When you download the inf (and the xtu installer), run them from your download folder.
Wyllow
That is how I run them. Same errors.
AlHill
Ok, what is the complete version of your OS?
Wyllow
I am on 10.0.22631 Build 22631?
Windows 11 23H2
AlHill
Were you able to look at the bios video settings?
Wyllow
I was able to activate iGPU in the ASUS BIOS to get my "Intel Graphics" to show up.
EDIT: I am now able to run the "Intel Graphics Driver Installer". That is now running and installing.
DOUBLE EDIT: The Driver now shows up as the following after running the installer above.
AlHill
Ok, after the graphics install, try xtu install again.
Wyllow
I tried to run XTU installer after restarting my computer and it is providing me with the same "Unsupported Platform" error.
This is the error message at the end.
Yes, the Installer is running as ADMIN, this is not a User Restriction issue.
I also attached the XTU logs to this ticket.
