Processors
16101 Discussions
XTU wont work with WSA
Physicsjo
windows 11 build 22000.556
XTU v 7.6.0.37
works fine without WSA, but after WSA wont work
thank you
Alberto_R_Intel
Physicsjo, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of your Intel® processor?
If this is a laptop, what is the model of it?
Is this a new computer?
Did you build it? / When did you purchase it?
Did the Intel® XTU ever work fine before on this specific machine when WSA was enabled?
If so, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
megan3000
Valued Contributor I
WSA --> Windows Subsystem for Android
WSA runs as a virtual machine using Hyper-V
https://answers.microsoft.com/en-us/windows/forum/all/use-windows-subsystem-for-android-in-windows-11/3b34877e-1783-4e43-a612-7909f06ffc62
From XTU release notes:
Core Isolation Memory Integrity, Hyper-V, and Virtual Machine State are
incompatible with XTU. XTU is unable to function when these features are enabled
https://downloadmirror.intel.com/29183/XTU-7.6.0.37-ReleaseNotes.pdf
So, we can see clearly here, that this is a problem due to the known issue with XTU...
