Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12959 Discussions
Xeon 2nd Gen Processor shows lower performance in Speed comapared with 1st Xeon Gen CPU
LVCSR
I am a engine developer for automatic speech recognition (ASR) using KALDI framework.
I got a speed latency in processing the speech recognition after I changed CPU
from "Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz"
to "Intel(R) Xeon(R) Silver 4215 CPU @ 2.50GHz".
Intel Product Documents describes they are operated in different method (sky-lake vs cascade-lake) although their clock speeds are different about 0.1 GHz.
After I chcked their elapsed time in my each functions, the most largest time difference are in below:
kaldi/src/nnet3/nnet-compute.cc:237 (referenced from https://kaldi-asr.org/)
which is propagation part with a neural network model for acoustic model including layers such as TDNN / LSTM / GRU / CNN / ATTENTION.
And here is my compile option flags in g++ (I use a Intel MKL):
-msse -msse2 -mssse3 -msse4.2 -mavx -mavx2 -mavx512vnni -m64  -march=x86-64 -march=cascadelake -DHAVE_MKL -O3
Is there any missing flags for 2nd GEN Xeon Cascade-lake CPU acceleration?
OR, is there other settings for 2nd GEN Xeon CPU? (Main-Board Setting, Neural Network Structure, Math Library, etc. )
JoseH_Intel
Hello LVCSR,
Thank you for joining the Intel community
Just with an initial look in ark.intel.com Intel® Product Specification Comparison we can see the Xeon(R) CPU E5-2640 v4 @ 2.40GHz could be a faster processor based on it characteristics. It has a higher cache (25 Mb) and higher max memory size and the clock speed difference is not significant.
Been said that could you share the system details (board model, current firmware, total RAM, OS) based on this we will be able to try to replicate the issue and engage our engineering team.
We will look forward to your updates.
Jose A.
JoseH_Intel
Hello LVCSR,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. I will try to reach you back on next Monday 7th. After that the thread will be automatically archived.
Jose A.
LVCSR
Hello, Jose!
Thank you for your replies for my post and sorry to delayed reply.
Your requested information is attached using command "lshw -short"
main board & firmware
total RAM : 128GB
OS : CentOS Linux release 7.8.2003 (Core)
One critical thing I just checked is "Sky Lake-E PCU Registers" in lshw results.
Is their mainboard-related comapatibility of cascade lake CPUs?
I really really appreciate for your support and replies.
Sincerely,
LVCSR.
JoseH_Intel
Hello LVCSR,
Thank you very much for the information attached. One think that I did not quite understant is this question?
Is their mainboard-related compatibility of cascade lake CPUs?
And actually take me to my next comment about you are using a Supermicro board so the best option to get compatibility information would be with them directly.
And for the same reason we won't be able to perform any issue replication as per we only have Intel boards and CPUs available for this purposes, so once again it will be better to contact Supermicro
Jose A.
LVCSR
Hello Jose,
I checked Supermicro BIOS version is 1.10A (latest version : 3.5).
Furthermore, there is a description in Supermicro update notes that is relevant with Xeon CPU device generations such as Sky-Lake, Cascade-Lake, and Ice-Lake.
After updating BIOS version to upper version, I will check the speed and reply as soon as possible.
Thank you for your benevolent replies.
Sincerly,
LVCSR
JoseH_Intel
Hello LVCSR,
Thank you for your updates. We will wait for the outcome after updating the board BIOS firmware.
Jose A.
JoseH_Intel
Hello LVCSR,
I am just following up to double check if you were able to do some progress after updating the board BIOS. If not completed yet let us know if you require more time to accomplish this. i will try to reach you back on next Tuesday 15th. After that the thread will be automatically archived.
Jose A.
JoseH_Intel
Hello LVCSR,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
