Hi
I'd like to know if the Xeon 5630 to a Bus / Core Ratio 20 or 21? (Without turbo mode)
and is will it work without problem on a conventional motherboard? (Not server)
thank you
1) Bus/Core Ratio is 19. See http://ark.intel.com/Product.aspx?id=47924 http://ark.intel.com/Product.aspx?id=47924
2) Better check with the motherboard manufacturer
ok thanks, so if I want to have a multi of 21, it must E5640 (x21 without turbo mode, as the i7 920)
the E5630 with a multi of 20 (without turbo mode, and 19 with the turbo)
thanks
