Processors
16326 Discussions
Xeon CPU I/OAT xor/xor_val operations
harryji
Hi, I am using Xeon CPU (skylake) and want to utilize the intel I/OAT for xor/xor_val operations. But I found when the function dma_request_channel is called with mask for xor/xor_val, the return channel is NULL. It succeeded with a mask for memcpy. I am thrilled to know whether these two operations are not supported or I am in the wrong way to use them. The OS is linux 18.04 with kernel 5.9.9. Thanks.
Alberto_R_Intel
harryji, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this topic, we just wanted to confirm a few details about your system:
What is the model of the Intel® processor?
What is the model of the motherboard?
Was it working fine before in reference to the function dma_request_channel?
When did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html?
Albert R.
harryji
Hi Albert,
Here is the information you require:
Processor: Intel Xeon 6138P, Motherboard: S2600BT. The system works fine before calling the dma_request_channel function. I didn't make any hardware/software changes except the kernel update to 5.9.9. The issue appears in the work environment. The SSU file is attached.
(Virus scan in progress ...)
SergioS_Intel
Hello harryji,
Thank you for the additional information, when you are running the Intel I/OAT for xor/xor_val operations are you getting any type of error or log, if so can you please share those logs or a screenshot where you are noticing an error?
Additionally, can you please provide us the link of the Intel(R) product that you are using?
Did you notice this error before?
We will be looking forward to your updates.
 Sergio S.
 For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SergioS_Intel
Hello harryji,
We are following this thread and would like to know if you need more assistance.
 Sergio S.
SergioS_Intel
Hello harryji,
We are following this thread and would like to know if you need more assistance or if we can close this thread.
 Sergio S.
JoseH_Intel
Hello harryji,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
For firmware updates and troubleshooting tips, visit:
