Processors
13582 Discussions
Xeon Platinum 8180 support memory type 2400 or only 2666?
ptoa
n_scott_pearson
Super User Retired Employee
Let's get this right. The maximum memory bus speed listed for a processor is the maximum speed that was validated by intel and is thus warranted by Intel. Now, two important points:
  1. Operation at standard speeds below this maximum is also warranted. For example, if the maximum speed listed is DDR4-2666, then operation at DDR4-2133 and DDR4-2400 is also warranted.
  2. Operation at memory bus speeds above the maximum is also possible (and, in fact, is regularly done) but, because Intel does not validate operation at these speeds, intel does not warrant operation at these speeds.
Hope this helps,
LeonWaksman
This CPU supports DDR4-2666 https://ark.intel.com/content/www/us/en/ark/products/120496/intel-xeon-platinum-8180-processor-38-5m-cache-2-50-ghz.html, however, you should see your motherboard specifications to find the supported memory. In the board spec, you will find other supported frequencies https://ark.intel.com/content/www/us/en/ark/products/120496/intel-xeon-platinum-8180-processor-38-5m-cache-2-50-ghz.html
Leon
ptoa
thanks leon :)
If the motherboard support also other memory type it will not work because of the limit of DDR4-2666 from CPU, so i need DDR4-2666 to work.
n_scott_pearson
Hope this helps,
Emeth_O_Intel
Thank you for contacting Intel Xeon Community.
I would like to know if the information provided by Scott P. helps you to have a better understanding of those details asked.
If you have more questions do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Intel® Server Specialist.
A Contingent Worker at Intel.
Emeth_O_Intel
Hello Ptoa,
I hope the information provided helps you to have a better implementation of your system.
If you have more questions do not hesitate and contact us back and we will be more than happy to assist you.
Have a wonderful day.
Emeth O.
Emeth_O_Intel
Hello Ptoa,
I was following up on your case and I have not seen any activity recently.
I am going to proceed and mark this thread as closed, I hope the information provided helps you to have a better understanding of the memory type supported for the Intel® Xeon® Platinum 8180 Processor.
If you have more questions, please do not hesitate and contact us back.
We will be more than happy to assist you and provide you the most accurate information.
Emeth O.
