Processors
14531 Discussions
acer e5-511g n3540 couldn't install io driver
МГлин
Aser e5-511g, after installing fall creators update for win 10/64 doesn't work properly i2c bus, cause i couln't install intel i2c driver, it crashes system into bsod while installing, if i trying to install it manually, win goes to bootloop. Is there any ways to fix this problem?
Hello LydoeD,
Thank you for contacting Intel® Communities Support.
My best recommendation is to contact the laptop manufacturer since they are the one who can provide you the correct driver you need.
The reason why it's because there could be certain limitations such as electrical changes or hardware and Software restrictions.
You can contact them at:
https://www.acer.com/ac/en/US/content/support https://www.acer.com/ac/en/US/content/support
Stephen C.
