Community
cancel
Showing results for
Search instead for
Did you mean:
RWu
apollo lake pcie
dear sir
請問一下apollo lake可以設定一個X4 PCIE和兩個X1的PCIE,同時可以使用的情況下。
TKS@
Community Manager
Hello gen2,
Thank you for joining the Intel(R) Communities.
As per the translate option, I understand that you want to check if a PCIe configuration can be done with the Apollo Lake processors. For sure we can check that out for you.
The configuration 1x4 and 2x1 can be used. This depends on the PCI slots available on the system as well, so take that into consideration as well.
Information was taken from http://intel.ly/2wgfq8f http://intel.ly/2wgfq8f
Under: "PCI Express Configurations"
If further questions are present, let us know.
Esteban C
