please advise best configuration of CPU for using above subject matter.
Hello AMISH,
When it comes to creating systems or configuring components such as a processor, so it can work according to what the software is going to be used for, it is worth mentioning that we do not create our processors so they can run any specific third-party software such as AutoCAD.
If you are planning to set up a build or to change your processor for one that is more powerful for example; so it can run this program better, bear in mind that every software developer such as the one for AutoCAD, during their development process they come out with minimum and recommended specifications for your system to run this specific software so with this in mind, not only your processor is important, because your computer’s build whether is a laptop or a desktop system, is considered by them as an arrange of components that most of the time needs to meet their minimum and recommended specifications, therefore, we would highly recommend that you get in touch with their support directly to check on those specifications, and when you have them, you can start thinking what processor would you like for your laptop or desktop system and in case you need to check any specific technical specifications for it you are welcome to use our website.
Support website (AutoCAD)
https://knowledge.autodesk.com/support
Forums (AutoCAD)
https://forums.autodesk.com/?_ga=2.7229426.1544753221.1611337082-493887075.1611337082
Intel’s website
https://ark.intel.com/content/www/us/en/ark.html
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Hello AMISH,
Please let me know if you need further assistance.
Victor G.
Hello AMISH,
We have not heard back from you.
Victor G.
