Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12773 Discussions
cambio de procesador
MarioEZ
buenas tardes,tengo una laptop toshiba satellite u405-s2833, con un procesador intel core 2 duo cpu t8100 @2.10ghz, 2101mhz, 2 procesadores principales 2 procesadores lógicos, estos datos me salen al consultar en información del sistema, ya en físico el procesador tiene la siguiente información, intel 06 5750B164 SLAUU, FF80576T8100 2.10/3M/800, quisiera saber por cual puedo reemplazarlo para darle un mejor rendimiento a mi laptop, de antemano agradezco su ayuda.
AlHill
You will have to ask toshiba what processors are supported by their bios.  Then, you can select from those.  And, this is only possible if your t8100 is NOT soldered to the motherboard.
Also, your processor is from 2008.   You will not see any significant performance increase.
https://ark.intel.com/content/www/us/en/ark/products/33916/intel-core2-duo-processor-t8100-3m-cache-...
You should plan on purchasing a new or newer system, with an 8th gen or later processor.
[Windows 11 is the new Vista]
