Processors
16334 Discussions
cant install drivers i7-9700 3 GHz 8-Core Processor
Jim73
GPU: Asus ProArt OC GeForce RTX 4070 12 GB Video Card
Motherboard: MSI Z390-A PRO ATX LGA1151 Motherboard
CPU: Intel Core i7-9700 3 GHz 8-Core Processor
I cannot update the drivers on this processor i may just be confused but windows 11's automatic drivers updating system is not correct. The driver says its from 2009, but the one i need is clearly not that one. They wont install with the assistant or manually.
n_scott_pearson
In Desktop systems, by default, if the BIOS detects a discrete graphics (dGFX) engine, it will disable the integrated graphics (iGFX) engine. As a result, you will be unable to install the iGFX driver package as the iGFX engine will not be visible.
If you need the iGFX engine, in order to support the connection of additional monitors, for transcoding, etc., you need to modify the BIOS Configuration to indicate that you want the the iGFX engine enabled always. If none of these it the case, however, simply stop worrying about installing the iGFX driver package.
Hope this helps,
