Hi
I recently installed XTU for my 7980XE. The default max frequency after enabling XMP is 4.2GHz, which is a little bit too high for me due to the cooling problem (too loud..).
So I have to change the ratio from 42 to 38 in XTU every time after I reboot my computer. Is there a way to set/change the default ratio in XTU ?
Yangyang
Hello silentlistener,
Thank you for contacting us.
I understand that you are experiencing issues setting the default ration value in Intel® Extreme Tuning Utility (Intel® XTU)
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
As well, can you please provide us with the XTU version that you are using?
I hope this helps.
Diego S.
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
