Community
cancel
Showing results for
Search instead for
Did you mean:
JLiao3
cherry trail Z8350 USE NFC function
1、我看到cht的内核中已经有对NFC的支持,请问在CherryTrial(android平台)中如何使用NFC?
2、我大概的看了下驱动,NFC驱动使用到了intel MEI,可以提供MEI的firmware吗?
3、请问如何修改BIOS以支持cht内核中自带的pn544驱动?
Community Manager
Hello JACKLXL,
Thank you for joining the processors community.
I am using a translator tool in order to understand your inquiry; however, the translation is not accurate and there is some information missing from your sentences. Since this support channel provides English support I kindly request to re-phase your inquiry on this same language. I would also like to let you know that we have a direct support for the Asia-Pacific region, this should be a faster interaction and in your native language, find the contact information here: https://www.intel.com/content/www/us/en/support/contact-support/apac-contact.html Support Contact Information for APAC
Amy C.
