what is the diffrence between DH55TC and DP55WG in perfomace with core i5-760 processor,which is the better one in two diffrence boards?
Hello;
You can compare between both desktop boards here:
http://ark.intel.com/Compare.aspx?ids=40078,42408 http://ark.intel.com/Compare.aspx?ids=40078,42408,
In regards your question, both desktop boards will give the same performance if you use the i5-760 processor, now you have to take in consideration that thise processor does not have integrated graphics and if you use the /Product.aspx?id=40078 Dp55wg you will need to use an integrated video, since this desktop board does not have onboard graphics
You can check your processor specifications here:
http://ark.intel.com/Product.aspx?id=48496&code=Intel%c2%ae+Core%e2%84%a2+i5-760+Processor+(8M+Cache%2c+2.80+GHz http://ark.intel.com/Product.aspx?id=48496&code=Intel%c2%ae+Core%e2%84%a2+i5-760+Processor+(8M+Cache%2c+2.80+GHz)
