Hello, i am using 8700 non k and when i stress my cpu with intel burn test it gets over 95 within two minutes or less, i am very worried and idle temp is 32-40. i applied thermal paste but didn't help at all.what should i do? thanks. my temp under high pressure blow
As long as you are under 100C, you are ok. And, the processor can do so much more than just run stress tests.
Doc
i get what you're saying good sir but 100 is considered very risky
100C is the max, + or - a bit. What did you expect the stress test to do?
Just stop running stress tests and you will not have a problem.
Doc
