Processors
15866 Discussions
current/EDP Limit Throttling on cori7 12700
frshte
Hello
 As the image I have attached i faced with current/EDP Limit Throttling error permanently. how could I fix this problem?
Alberto_R_Intel
frshte, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
For this scenario, first, it is important to mention that the Intel® Core™ i7-12700 processor is not listed as supported by the Intel® XTU:
https://www.intel.com/content/www/us/en/support/articles/000057552.html
Current/EDP Limit Throttling
There can be multiple reasons why the current/EDP throttling is set on the processor. Three common reasons are the following
-Processor Core IccMax is set too low in the Intel® XTU.
-VR (voltage regulator) current limit is set too low in BIOS. Different motherboard OEMs may have different names for this control. On this topic, we recommend to get in contact directly with your motherboard vendor for further assistance on BIOS settings.
-The motherboard is not able to provide high enough current for the given processor. Pairing a low-power motherboard with a very high Thermal Design Power (TDP) chip can cause current/EDP throttling, even with current limits set to the maximum. Which also is supported by the manufacturer of the motherboard.
Albert R.
