Processors
16316 Discussions
did the ram adata AX3U1600GB2G9-2G buss 1600 work with cpu 2500k
m2010
did ram adata AX3U1600GB2G9-2G buss 1600 work with cpu 2500k
m.b. asrock z68 pro 3
ram with volt 1.65
Adolfo_S_Intel2
This processor supports up to 1333 MHz FSB, so if you install RAM running at 1600 MHz, this RAM will be running at 1333 MHz. in this case I would recommend contacting the motherboard manufacturer for a list of tested RAM for this system.
m2010
my board is asrock z68 pro 3 and buss in the list of memory but i asked if there any dangrouse with the volt 1.65 on my system hardware that the quition?
Adolfo_S_Intel2
You should not have any issue, however we do recommend using 1.5 Volts RAM if possible.
m2010
the ram will work,
what could hapen if i work with ram with volt 1.65 constantly
