How to disable the XTU's writing log files? as they take a lot of size of my C: drive space without affecting the system performance
I can't stop saving logs even using intel extreme tuning utility app at advanced setting--> disable logs .... what can I do also to stop saving logs and erase them?
Thanks in advance
Ibrahim-Noble, Thank you for posting in the Intel® Communities Support.
In reference to your question, just to let you know, the Intel® Extreme Tuning Utility is fully compatible only with Extreme and Unlocked Intel® processors, as you can confirm in the link below at the bottom of the page for the list of supported processors:
Since your computer is working with the Intel® Core™ i5-9300H and that processor is not fully supported by the Intel® XTU, it is expected that some features of the application might not work as expected due to compatibility between the toll and the platform.
Albert R.
