17334 Discussions
disabling turbo boost
Bun
Hi
i have a 10750H i7 that spikes up to 95C when opening a program ,chrome tab ...
and get that same temp whyle gaming depending on the game if i use max fans i can get down to 80 70C  but thats too anoying
the cpu works normally  up to its max freaquency
my question is what would happen to my cpu if i either :
     Disable turbo boost
      or just down clock in throttlestop
besides getting lower performance i want to know if this affect my cpu lifespan
     Or if you think that my laptop can support consistant 5h of 95C without catching fire or melting i can set silent mode in msi dragon center and keep using it (((((((((i know that it will explode so forget this)))))))
MSI GF75 thin
Jocelyn_Intel
Hello, @Bun
Thank you for posting on the Intel® communities.
I am sorry to hear what is happening with your laptop, I will do my best to assist you here.
Please take in mind that these temps may be expected as we are talking about a laptop system, which as per hardware design, most of the time has higher temperatures than a Desktop system, especially if you use it for gaming. Also, the processor can go up to 100C degrees.
Does these temperature spikes are causing any kind of BSODs or crashes?
Intel® Turbo Boost Technology won't cause the system to get too hot as the core performance increases in power, temperature, and specification limits of the thermal design power (TDP). Sometimes, when Intel® Turbo Boost Technology is running, the system fan may run at a faster speed, which is normal when boosting the processor frequency. Ensure the processor is working within the power, temperature, and specification limits of the thermal design power (TDP). You can verify this in this article: Overview Information for Intel® Turbo Boost Technology
Besides that, even if you disable Turbo boost or downclock the processor, that doesn't guarantee that the processor will not heat up since it’s a laptop, as previously mentioned, these temps are kind of expected. Note: Please make sure to use the processor within its specifications if you decide to downclock the processor, as using it below or above its specifications can reduce its useful life and void the manufacturer's warranty.
Jocelyn M.
Bun
i dont get any BSOD
the systhem runs fine
and when i disable turbo boost either in control panel by makong 99% in cpu powre setting or bios itself i do get lower temp up 40C
On the specification limists :
     in throttlestop i saw that when i satrted a game power consumption got up to 51 then the cpu throttled because it was 98C and got it self down to 90C 95C
Jocelyn_Intel
Hello, @Bun
Thank you for your reply and confirmation, I am glad to hear that you are not getting BSODs or crashes.
Regarding the information you mentioned, we are not aware of the information provided by a third-party app like Throttlestop or if it is accurate, I will try to do some research about this.
As soon as I have updates, I will post them here.
Jocelyn M.
Jocelyn_Intel
Hello, @Bun
Thank you for your time.
There are a few tools like  HWinfo, HWMonitor, AIDA64, and a few articles on the website you can use: 11 BEST CPU Temp Monitor Tools: PC Temperature Monitor 2023
Those are not Intel official tools and can get different results from each other, however, we can rely on those tools for a measure, however, you are not presenting any performance issues (such as BSODs, crashes, etc.), is not considered an issue, there is nothing to actually be worried.
As previously mentioned, the processor can go up to 100C degrees, high temperatures are expected, especially under heavy workload. If you still thinks there is something unusual with your laptop, contact your System Manufacturer for additional assistance and check the life status of other components.
Jocelyn M.
Jocelyn_Intel
Hello, @Bun
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Jocelyn_Intel
Hello, @Bun
As we have not heard back from you, we will proceed to close this thread now. If you need any additional assistance, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
