Are the dual 2.8 GHz processor and the 2.8 GHz core 2 duo processor the same thing or is this two different animals with similar nomenclatures? I want to buy Adobe CS4 Production Premium and the minimum system requirement is a dual 2.8 GHz processor. I have been given vague and conflicting information from various computer vendors regarding this topic. Thanks for clearing this up for me.
dir sir
how to know processor 2.8 GHZ my prod code is BX80571E5500
MM 907806
FPO/ BATCH 3017B593
PLESE VERIVI THE BATCH
THANKS
KISHOR
They are 2 very diffirent animals like you put it. For Adobe CS4 a dual or quad core CPU is sufficient. If you want to render a lot of things then you might start thinking about a dual-CPU system.But this brings al lot more power requirements into the mix and usually a lot more noise.
By the way, if you want to speed up software like Adobe CS4 then you might think about getting a professional graphics card (nVidia Quadro or AMD FireGL) which would speed up the software more than a CPU would.
What Motherboard do you have , Because if you are going to be doing editing or video , you want the best CPU that your board can handle.
Also if your board can handle Crossfire, you may want to concider two HD5770 GPUs.
