Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11671 Discussions
e5-2670 ecc memory
IMiha2
Hello, I have seen that 2670 suports ecc memory but is it required? I have a dual cpu build on an asus z9 pe d8 ws with 2 sticks of 8gb ddr3 hyperx at 1333mhz and it give me the 53 error code on the motherboard. The question is do I have to get ecc memory or is it something else wrong.
AlHill
You must use what the asus board supports and what they tell you to use:
https://www.asus.com/us/Commercial-Servers-Workstations/Z9PED8_WS/specifications/ Z9PE-D8 WS | Servers & Workstations | ASUS USA
Specifically:
8 x DIMM, Max. 64GB, DDR3 2133(O.C.)/2000(O.C.)/1866*/1600/1333/1066 MHz ECC, Non-ECC, Un-buffered Memory **
Quad Channel Memory Architecture
*For Registered Memory, Max. 256GB DDR3 1866/1600/1333/1066/800 MHz
** Refer to http://www.asus.com/ www.asus.com for the Memory QVL (Qualified Vendors Lists).
Doc
IMiha2
I am using 2x 8gb ddr3 hyperx at 1333mhz as far as I understand it should work. Or do I need to populate all 8 dimms? Does the 2670 REQUIRE ecc memory or it works with ecc and non ecc? Still not sure but thank you for your quick answer.
AlHill
No, the e5-2670 does not require ECC.
If your memory meets the specifications of the motherboard, then it should work. I will leave that to you to determine.
No, you do not need to populate all 8 slots.
Support for these questions is best obtained from Asus.
Doc
IMiha2
