Processors
14538 Discussions
es posible que agregar una opcion para aumentar la velocidad del fan cooler en Intel(R) XTU(Extreme Tunning Utility)
ECabr3
lo digo porque quiero que agregen esa función porque al hacer overclock se utiliza mas energía que pasa por un pequeño chipset que se caliente mas por el aumento de voltaje,entonces el ventilador tiene que disipar mas calor pero para eso tiene que ser mas rapido por eso quiero que agregen esa opción a intel xtu
AlHill
What is the model number of your processor?
Doc
n_scott_pearson
This should be happening automatically. If it is not, it is something wrong in your motherboard, its configuration or its BIOS.
It is not within XTU's perview to implement this type of control (fan speed control is implemented in many different ways; XTU cannot know them all).
AndrewG_Intel
Hello ECabr3
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded in this Intel Community.
We would like to inform you that we will send your feedback to the proper department for consideration, however, we cannot guarantee it is going to be implemented. Also, we will not have visibility about future plans and/or releases regarding features, updates, and development of Intel® Extreme Tuning Utility (Intel® XTU).
Thank you for taking the time to share your comments and feedback, it is really appreciated.
Andrew G.
