Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12942 Discussions
game crash in 12th、13th Gen Processor Graphics
Directx90C-Crash
I'm a game developer, and game crashes are frequent and random on i5-12600K and i5-13600K,
Steven_Intel
Hello Directx90C-Crash,
I am sorry you are having issues with your Intel Processors. I'll be glad to help you.
We would like to know further details about these crashes and also which games are having the issues, in order for us to investigate.
I look forward to hearing from you.
Steven G.
Directx90C-Crash
Hello Steven G.
thank you for reply.
The game frame where the crash occurs cannot be reproduced when the game video is played again, so maybe there is no inevitable connection between the crash and the same rendered content
But the program stack is the same every time it crashes
You can download the game from:
https://www.aliyundrive.com/s/CAyUekS2xmm
ax30
decompression then double-click v.bat to play video,then wait the crash
SystormX
Maybe I'm blind, but I don't see any information(at least) about which OS you using. Did you try any other PC with CPU with older architecture? What temperatures do you have while running those operations? Maybe it just the software bug?
Directx90C-Crash
Sorry, my introduction is not comprehensive.
OS is win10 or win11,I don't have a PC with core graphics card in the old architecture, The game runs normally on GTX960, GTX1060.
Maybe it just the software bug,Crash occurs when d3d9->DrawPrimitive is called,and then into d3d9on12.dll。
So I'm here for help。
SystormX
You probably should have asked this question on Microsoft forum instead of here first, because it's  DirectX error. I don't think that someone here can help with that problem. Maybe even on Nvidia forum, if such exist.
SystormX
SystormX
"DX* is property of and is sustained by Microsoft. Troubleshooting of DX* apps and games issues require Intel to promote any findings to Microsoft Support so they can include the proper fixes in their next update of the operating system and the DX APIs."
 So? You want to Intel to tell Microsoft about this problem? I hope they will. Good Luck. I'm out.
Directx90C-Crash
Steven_Intel
Many thanks for your reply.
Please keep in mind that in order for us to report a crash/issue, we need to be able to replicate it on our end, and we may need to request additional information from you, to confirm the actual source of the issue.
Please confirm the following information:
  • Is this issue happening while running the game using Intel integrated graphics?
  • If the above is correct, what is the graphics driver version you currently have installed?
  • What is the name of the game?
As well, the link you have provided does not seem as secure. Is there any way to directly download this game from a secure platform/source?
Steven G.
Directx90C-Crash
1,Yes, it appears on 12600k and 13600k 's integrated graphics
2,I have tried several versions of the driver, including the latest 31.0.101.3790,all have this problem
3,It is a Chinese Game,named "群雄逐鹿"
download link:
https://1drv.ms/u/s!AmPgyi-rId7UdbUk7-m5nH4e3NY?e=aQ9RMN
decompression with 7z,run v.bat to play video,then wait the crash
Steven_Intel
Steven G.
Steven_Intel
Many thanks for the information provided.
I will keep working on this. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
In order to continue, please provide the following two reports:
  • On Windows, look for the Intel® Graphics Command Center > Go to Support > Click on System Diagnostic > Click on Generate report > Save the report as a .txt file and attach it to your reply.
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Directx90C-Crash
Steven_Intel
Thank you for your response.
While we work on this, please perform a clean installation of the latest graphics DCH driver 31.0.101.3790 (https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html) and check if the issue persists.
Make sure to follow the clean installation instructions: https://www.intel.com/content/www/us/en/support/articles/000057389/graphics.html
Steven G.
Directx90C-Crash
I update the driver to latest, crash still come. reports is attached.
please use game-20230104.exe to reproduce the crash(in old version, the camera does not move, so maybe no crash).
https://1drv.ms/u/s!AmPgyi-rId7Ud9aIusAD2x3whsM?e=tMjRdG
when crash is done,  the message will showing:
Best regards
Steven_Intel
Steven G.
Steven_Intel
I will work on this and as soon as I have an update, I will let you know.
Steven G.
Steven_Intel
I just wanted to let you know we are still working on this issue. As soon as I have the results, I will make a post here.
Many thanks for your patience.
Steven G.
